Yo yo.
R34 GTsT. 3" turbo back exh- Walbro 500 hp pump- JustJap Turnflow FMIC- Mushroom filter in box- Standard ECU, Injectors and AFM- Greddy profec B- Greddy RS BOV plumbed back into intake.
I've been having some real headaches with how my car puts down the power. In a nutshell, anything over 7psi (my Hi boost is set to 9,5) turns my car into a pig rich fuel guzzling, retardation machine. At first I thought it was R&R, and changed my plugs, AFM, and got hold of another standard ECU. Coilpacks are fine, and no boost leaks as boost comes on consistent and strong.
So I took it to Pulse Racing to see how it looked on the dyno. Check out the pics attached. Their Dyno reads at it's lowest A/F point of 10:1. My cars AFR flatlines at 10:1 or possibly lower right from the beggining of the run. Check out the crazy power dips to and a max of 126 rwkw.
I need some help in getting some ideas what the problem could be. Replacement standard ECU made no difference, and simply "chucking in" an aftermarket item isn't going to fix the problem either...
Tuner recons it's not the 02 sensor, coils, plugs, boost control, but pretty much tried to "sell" me the idea of an aftermarket ECU, which really, is a bandaid fix to the actual issue. I want to diagnose the cause of the issue. Any help is appreciated
Cheers
https://www.sau.com.au/forums/topic/338107-worst-dyno-results-ever/
First thing I saw was Walbro fuel pump, did you use the stock wiring (6v / 12v depending on load) or did you give it alternator voltage like A/M pumps such as Walbros need?
i hardly think theres any problems with lack of fuel flow looking at the graph....
Yo yo.
Cheers
Are you sure the injectors are stock? Something doesn't add up... Checked fuel pressure?
He suggested an aftermarket ecu because he cant adjust anything without it.
To Moodles2, It was happening prior to the Walbro pump install, and if anything, it's getting too much fuel rather than not enough. the Pump was installed by Autosport engineering, who I dare say know what their doin. It wasn't a backyard job.
To Scotty, I haven't checked if the Injectors are standard. I would assume so as but will check that out for sure.
My thoughts are it's not necessarily the ECU at fault here. yes i kno that their is a safe map for knock etc with the Nissan standard unit, but there is no way that the map is "lets drop AFR to 10:1 through the entire rev range"
Get an ecutalk or other consult reader and get some idea of what is going on - injector duty, afm readings (can you swap out the afm with someone?) And get a Nistune chip so that you can actually try to tune it. It will also help to identify problems.
How has no one mentioned the fact he thinks he owns a R34 GTST? :D
Haha yeh i noticed that.
So is that run on stock boost?
Did u try running a higher boost setting. Like 12 ?
Check coolant temp sensor too. Its like its on cold start enrichment
check the boost sensor is hooked up, and secondly that the boost source for the BOV is connected. If either are missing it will do that... as will a split hose (cooler)
Second dip is normal as the std ecu has a big timing drop in i, run std boost and dip goes away... or a quick remap removes it straight away.
yes
ECR33 has excess airflow protection
ER34 has excess airflow protection
ER34 also has excess boost protection via the 2nd map sensor that runs to the ECU
its likely you are just tripping that out, youll need a remap, a map sensor cut device, run it no where and crimp the vac line or get a stand alone
Lo boost on Greddy - gain 28% set gain 13% Start gain .46 gives me about 7.3 peak boost
Hi boost on Greddy - gain 38% set gain 18% start gain .55 gives me about 9.3 peak boost
Running "lo" boost is fine
Running "hi" = what you see on the dyno charts
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
