Maxing Small 21u Rb25det R33 Turbine Housing With High Flow. What Power Would You Expect?
I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow.
I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel.
The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot.
Video footage for all 3x runs are recorded:
I'm little bit concert with high back pressure. So this profile will not yet be commercially available after further testing and examination for component wear.
very nice, may i ask what supporting mods are used to achieve the above power figures, besides the already stated? also what would be a ball park figure on getting one of these done if it were to go commericially available? cheers and good job.
It runs off a factory standard rebuild engine with stock engine head with fuel mods. There is nothing in there that could alter the behavior of the turbo on a stock setup.
The heat would be a major problem. We did a check up run after the turbo cooled down, made 293rwkws. lol Any thing above 270rwkws for this housing isn't consistent. I will remove this turbo off the test car in few weeks time and see what the bearings and collars be like, If nothing is excessive then this will be replacing the current 240rwkws profile.
Its the same car he run 300+kw in last week with a different turbo..
Man that car has a different turbo in it every week... :happy:
Power curve actually looks pretty sweet too..
I have achieved similar results on more than 1 rb25 using a highflowed rb25 turbo with the OP6 housing and tolulene mixed fuel running a very agressive tune (all supporting mods including cams and a VERY freeflowing exhaust).
I have never posted dyno charts (and don't intend to) because some keyboard warrior is just going to call me a liar.
what about exhaust manifold gas temps? i wouldnt be worried about the turbo... its the valves i would be worried for!
plus the extreame temps isnt going to help with knock and summer is around the corner... i would be toning this down a bit for safety
we are talking pump 98 here no jungle juice.
impressive, but, to me it looks laggy for a std 33 housing! never thought id say that about a factory housing lol.
a bar at ~3700 and full boost at ~4000.
looks very similar to a OP6 / 3076 curve. a good cheaper? alternative.
nevertheless a good achievement for a 33 housing. good street only turbo.
dont worry about the heat, its not like you would have it that hot on the street...
I agree, its not like you are pumping that power out continuously on the street but an egt gauge would be a good idea. With a smaller exducer you wouldnt loose all that much top end, as the nozzle is the restriction, but it will come on much earlier.
I have 20 psi by 3k, dropping to 17 at redline, I plan to try the added spring first but what actuator was this running?
Its running a high pressure actuator with a gate controller. Its not possible to hold boost on the actuator alone. and that is a 23psi atmospheric scaled actuator.
The power curve looks pretty average compare to the ATR43G3s, but on road this is very responsive, comes in boost nice and early on 1st, 2nd, 3rd, totally different driving ability compare to .82 rears.
Everytime i read your threads and all the power and response your getting from hi-flows etc it just confuses me more which one to go for! haha
Ask Tao to post up a ramp rate comparison, ive had a few cars come in lately that are being tuned on unrealistic ramp rates, this ramp rate moves the curve around alot. the above graph will make 18o-200rwkw @ 4000 by runnning a pretty popular Dyno Dynamics ramp rate.... makes for a nice graph but unrealistic.
Man that car has a different turbo in it every week... :)
You do realise he owns/works for a turbo company Hypergear and that car is a demo vehicle...
I wonder just how hot it would run when pushed hard.
I see people saying it would be OK for good power on the street, but personally that would mean dead engine in my hands.
@ 270 we could do run after run without issue @ 290+ it was starting to heat up and required constant timing chances to keep it happy. do 2 or 3 runs and the timing would fall back to where it was @ 270... then it would do run after run @ that timing all day long with around 3 degrees headroom
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
