Maxing Small 21u Rb25det R33 Turbine Housing With High Flow. What Power Would You Expect?
I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow.
I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel.
The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot.
Video footage for all 3x runs are recorded:
I'm little bit concert with high back pressure. So this profile will not yet be commercially available after further testing and examination for component wear.
very nice, may i ask what supporting mods are used to achieve the above power figures, besides the already stated? also what would be a ball park figure on getting one of these done if it were to go commericially available? cheers and good job.
It runs off a factory standard rebuild engine with stock engine head with fuel mods. There is nothing in there that could alter the behavior of the turbo on a stock setup.
The heat would be a major problem. We did a check up run after the turbo cooled down, made 293rwkws. lol Any thing above 270rwkws for this housing isn't consistent. I will remove this turbo off the test car in few weeks time and see what the bearings and collars be like, If nothing is excessive then this will be replacing the current 240rwkws profile.
Its the same car he run 300+kw in last week with a different turbo..
Man that car has a different turbo in it every week... :happy:
Power curve actually looks pretty sweet too..
I have achieved similar results on more than 1 rb25 using a highflowed rb25 turbo with the OP6 housing and tolulene mixed fuel running a very agressive tune (all supporting mods including cams and a VERY freeflowing exhaust).
I have never posted dyno charts (and don't intend to) because some keyboard warrior is just going to call me a liar.
what about exhaust manifold gas temps? i wouldnt be worried about the turbo... its the valves i would be worried for!
plus the extreame temps isnt going to help with knock and summer is around the corner... i would be toning this down a bit for safety
we are talking pump 98 here no jungle juice.
impressive, but, to me it looks laggy for a std 33 housing! never thought id say that about a factory housing lol.
a bar at ~3700 and full boost at ~4000.
looks very similar to a OP6 / 3076 curve. a good cheaper? alternative.
nevertheless a good achievement for a 33 housing. good street only turbo.
dont worry about the heat, its not like you would have it that hot on the street...
I agree, its not like you are pumping that power out continuously on the street but an egt gauge would be a good idea. With a smaller exducer you wouldnt loose all that much top end, as the nozzle is the restriction, but it will come on much earlier.
I have 20 psi by 3k, dropping to 17 at redline, I plan to try the added spring first but what actuator was this running?
Its running a high pressure actuator with a gate controller. Its not possible to hold boost on the actuator alone. and that is a 23psi atmospheric scaled actuator.
The power curve looks pretty average compare to the ATR43G3s, but on road this is very responsive, comes in boost nice and early on 1st, 2nd, 3rd, totally different driving ability compare to .82 rears.
Everytime i read your threads and all the power and response your getting from hi-flows etc it just confuses me more which one to go for! haha
Ask Tao to post up a ramp rate comparison, ive had a few cars come in lately that are being tuned on unrealistic ramp rates, this ramp rate moves the curve around alot. the above graph will make 18o-200rwkw @ 4000 by runnning a pretty popular Dyno Dynamics ramp rate.... makes for a nice graph but unrealistic.
Man that car has a different turbo in it every week... :)
You do realise he owns/works for a turbo company Hypergear and that car is a demo vehicle...
I wonder just how hot it would run when pushed hard.
I see people saying it would be OK for good power on the street, but personally that would mean dead engine in my hands.
@ 270 we could do run after run without issue @ 290+ it was starting to heat up and required constant timing chances to keep it happy. do 2 or 3 runs and the timing would fall back to where it was @ 270... then it would do run after run @ that timing all day long with around 3 degrees headroom
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
