Thanks for the heads up guys, I went down to Supergas for a winge today and ended up speaking to the sales manager on the phone while at the counter. He ended up giving me a 10.5m3 refill for $125, less than half what I was paying.
I don't have pics of the damaged manifolds, one I had to repair, and one I saw on a car, the crack was definitely down in the webbing but it could have started beside the weld and cracked further away as it made it's way around the pipe. I didn't get a good look at it as it was on the car. It was probably 2mm tube so very thin and light stainless. It would glow white hot on the dyno within a second or two of hitting boost. My point was, he had a GT42 mounted without a hanger or support, and a 4 inch exhaust with no hangers till the diff. Perhaps it would have lasted longer if the manifold could move around on the head a little and the turbo was supported.
Still need to make a inlet for the bov
Let me know what you guys think !
Looks good Angelo, just face the BOV return towards the compressor, cut on a 45 degree angle, and weld it in. It will take a while to die grind the hole, partly the reason I use alloy for my intakes as it's much easier to shape the holes in.
Good news on the gas mate! What kunce though slugging ya that much a bottle especially when it looks like your a regular customer who does a fair bit of welding ;)
Im doing some pipework on my dads GTR tomorrow so hopefully I can get some pics up afterwards :)
I have a couple of vices, and a set of small vice grip pointy pliers. None are big enough for 4 inch unfortunately, I need to find a larger vice or find another way to hold larger tube.
I am making this 4 inch intake atm, for a GTX35 in a 33. The VQ afm should be good for over 450wkw resolution in 4 inch tube by my calculations. To be tuned with a PFC. :)
The reason thin walled china manifolds crack is due to expansion, they would crack just as easily if purged imo. If the manifold flange is split and the turbo/exhaust weight is carried by a well designed bracket of some sort, the manifolds would probably last for years (on road cars at least.)
I only purge exhaust pipes when the die grinder can't get to the back of the weld, this isn't food grade exhaust I am working on, and at $300 a bottle of argon I'm not going to waste it back purging unless I need to. I have never had any dump pipes or exhaust returned from weld failure either, track cars included.
One thing i can say, I definitely prefer to weld thin wall (1mm or thinner) while back purging as I am much less likely to blow holes and can crank much more current in. No doubt it is stronger, but this isn't a structural item we are talking about. Perhaps you get better pricing on Argon through your work Mick?
My 2c ... chinese manifolds crack not due to absence of support or purging...its purely down to the fact that there isnt any penetration. I have only looked at 3-4 China manifolds but none of them had any penetration. Even my old Greddy manifold only had intermittent penetration. Purging of course helps ontrol peno without cauliflower so is related.
Looks excellent! However, couldn't you have rotated the housing to avoid having that elbow?
Thanks. There was a reason i did it like that an I can't remember why haha, possibly due tithe size of the housing and manifold position it may have hit ac lines and compressor or pwr steering lines not sure it was a while ago. It was just easier to do that, plenty of big turbos are positioned the same. And since I was doing it in lobster back why not show off the stainless work. Edited by r32gtrs
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
