Caltex price theirs at 20c less than unleaded, the price will fluctuate daily. This is a national pricing structure apparently, the tax has also risen on ethanol just recently I think.
They state 70-85% ethanol, no mention of octane rating. Its higher than I need... :D
We've had it here in the switch for a few weeks now.
Octane rating is 105. The amount of ethanol in the blend will change from summer to winter but the ron rating according to them will not alter.
Great, so you dynotune your car on an 80ish % batch then refil the next week on a 70ish % batch and blow your motor.
Got to love garbage.
The amount of ethqanol in the blend will change from summer to winter but the ron rating according to them will not alter.
This I highly doubt, are your sure?
Dude i am telling you what they told me. Ethanol isnt the only way to up a ron rating. its been happenning for a long time without it.
Tested by another member not to be the case. Running E70 on an E85 map will cause it to run rich enough to negate the "drop in ron". Running E85 on E70 map shouldn't cause detonation unless it was a REALLY hot day.
Just get a wideband and keep an eye on it when you fill up.
Explain to me how a richer blend is going to "blow up" your motor?
All fuels have a rich max and a lean max figure to which they work best at, generally anything between the two will be OK. Anything above or below will result in potential detonation or poor combustion conditions.
Richer does not mean safer in all respects, it is generally accepted that richer is safer due to regular 98 properties. We are talking about lamens terms now and this should not be acceptable in something we put this level of money and developement into.
Fuel blends have always been seasonable with many companies, yet actual mixture percentages advertised at 15% variance is shocking.
Hope I didnt break your heart mate.
No hearts broken here. :D
If you are tuning near the limits of ethanol fuel I will be impressed. I havent heard ping for 8 months since I changed over. The engine protection benefits are huge and worth the drive to fill up, you dont have to push it at all from your 98 map, it will still give you extra power...
As I have already stated, I ran the Caltex e70 on an e85 manildra map and only saw a 1afr richer difference, not enough to do any damage thats for sure. The plugs dont foul with this fuel.
The Caltex I fill at has been selling ethanol for 2 months now and has gone through 2000L, how long do you think before the servo's tank is refilled?
Plugs will foul. Big deal. If you're running E85 and willing to risk it without a wideband, good for you. The money you saved on not covering the base with the wideband will come in handy when you buy new plugs so often.
Keep in mind, Caltex did NOT intend for people to be running this fuel in anything other than a flex fuel taxi. The flex fuel cars have an ethanol content sensor that tells the ECU how much % ethanol there is, and adjusts fuel and ign maps accordingly. Since we don't run this, we need to adjust ourselves. Get a map made on E70, as well as a map made on E85. Watch the WIDEBAND YOU PURCHASED when you drive off from the station. Watch the AFR's and work out in your head (should be simple) what % you just filled up with. Swap map if need be.
Hell, cover ALL bases and have 3 maps made, E70, E77.5, E85.
Just ask the attendant how big the tank is
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
