  • Replies 60
howbout ask in the wheel size thread??
although 20s is a bit silly and pointless. you may be feeding the trolls with this one. dont do it, you'll wind up with a rep like the guy who started the 22s on an r33 thread bahaha
at least it gives me another chance to post my graph... :D
hahaha i knew that was only a matter of time before that happened. although i think the graph could be revised to include other known characters that are far more ridiculous than the likes of richard simmons. i cant see him having 22s on his shopping list. howabout the likes of 50cent, or one of the sparkly faggots from twilight. someone who we can justify ridiculing and compare their likeness to those who lust after the excessively large wheels because their penis just doesnt cut it for them, or anyone else for that matter.
i have to congratulate the OP. your probably now on your way to becoming a laughing stock, along with the likes of Buddy and the infamous La Bomba
unless your car looks this good.
forget it son, hand the keys in at your local used holden dealer and pick yaself up a hectic vt commowhore.
The above is probably more epic fail than 22's on a 33, or 20's on a 34.
Goes to show money can't buy taste :D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
