Firstly id like to know if anyone on SAU has gone down the twin EFR7163 path and what kind of results did they net. The turbo is rated at 550hp so would you need to run big boost to hit 1000 ?
I did have a set very early on (3yrs ago), they were prototypes so I'm not sure if the current 7163's are the same config.
Paul is correct, 20psi around 5500 and went on to make approx 600hp from memory. Didn't push them past 20psi so I have no idea where they would end up.
Roughly 1,000,000 going by Borg Warner's claims for them - they are beyond the Garrett GT3076R/HKS 3037s in flow rating, which used to be strictly "Pro GTR" type territory in the good old days of Japan drag racing. Serious serious business, so that lag isn't that surprising and realistically actually pretty impressive given what would have happened if you wound the boost up to 11. Not really ideal on a 2.6litre circuit car though!
When i started my build i had roll drags and 1/4 drag as my main priority. Ive since become more roll and top speed oriented seeing that i want to attend SM1000 next year. Ive got a 2.8 stroker with 288deg kelford cams, i think my cams might be to big for these turbos? I will be on E85, high comp and big boost. I do not want to make another mistake in my turbo choice. Its either going to be twin EFR's or a big single huffer for me.
Edited by Tyranus
Hello Guys,
Been reading this topic for a while now ... just caught up :P
Just orderd an 7670 1.05 a few minutes ago for my rb25 build (r33)
Hoping to get around the 500bhp out of this setup for a nice quick street car :)
rb26 crank
rb26 JE pistons
Eagle rods
custom manifold (2 38mm tial mvs)
delete the vct and put kelford 262 cams in there
Supertech springs
And the suporting mods for these kind of setups(fuel pump/injectors etc)
All will be at euro 98 fuel since we can get that at most places here.
  • Like 1
Hello Guys,
rb26 crank
rb26 JE pistons
Eagle rods
Supertech springs
Sounds like an awesome setup!
So you can put some super sick Kelford cams on It Paul.. Farrrrkkk don't you know anything?
Kelford are awesome, I'd put them on anything except an RB25 - nfi why they don't do a VCT cam for them... my only guess is they don't sell enough for those motors to justify the R&D :(
I need to purchase the cams so its not set yet.
Its just that I want to see something else then the std choices everybody makes.
Hope that it would not be a bad choice to delete the vct that it would realy effect the power.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
