Overrated mate save your money. Your response looks better than an 8374 for sure.
I have never seen a convincing dyno chart for and rb26 or 28 yet even though these things have been out forever.
Will be interesting to see piggazis and Harrisracings when they eventually post a chart.
Sorry for the delays in my project, but I'm back on it and set my goals to have that thing dyno'd within 45 days. I'm trying like hell! Trust me, I want to see an 8374 efr dyno on a stroker as well :)
theres an RB30 + 8374 dyno chart from Chris Vautier (new zealand) somehwere in this thread: http://www.gtr.co.uk/forum/154737-sub-boys-r32-gt-r-then-now-66.html
Holy smokes is that really 630 whp on PUMP GAS?!
Well I'm hoping to hit my target of 550 whp on pump gas. Any more is Lagniappe as we say down here :)
Anyone running one of the newer T4 TS 6758's on an SR20? Can't find tooooo many people around with the setup. Thinking about going low mount T4 TS manifold and 6758 T4 TS 0.80 turbo (stiffer spring on internal wastegate) on my S15. It's daily driver. Some weekend warrior, and occasional track day. I'm all about that response. Poncam, Z32, 2000cc injectors, Forged engine, RB25 gearbox, Nistune (e85 Fuel).... was hoping for 300rwkw, maybe full boost around 3500rpm. Which seems to be a fantastic package, especially with that off boost and 'transient' response the BW are known for. Can anyone speculate on results of the TS 6758??
I know everyone totes the 7163, and I do love it, was considering in T4 TS version... however I just think I'll end up netting ~350rwkw which I just don't think is useable in an s-chassis.
"slow is smooth and smooth is fast" - some guy probs a while back.
Agreed that housing is more compact in everyway. My boost solenoid (8374) is out on the edge of the compressor housing as well. While mine fit well like it is, I bet the 90 degree is a better fit with piping.
Gcg got back to me and said they can get them in for the 6758. Not sure on other sizes. They don't carry them as they're brand new and don't have any on order yet. But maybe email them if anyone is interested in converting over.
these new BW 90 degress housings? Seems like would make pipe layout on an SR20det (S15 in my case) alot easier.
agreed- for SR20 s-chassis that 90 degree housing B1 turbo posted above can help clean up pipe routings. They are much more expensive housings however
for the bigger 8374 and 9180 turbos, these already come with an optional vband you can add a 90
I have not tried the TS6758 but I agree it may be a perfect combination for what youre considering. You can use it with the 90 degree housing I have a beater S14 with SR20 and was running an old 6258. it works so well on a junk setup for 350hp that i dont plan to change anything
Holy smokes is that really 630 whp on PUMP GAS?! Well I'm hoping to hit my target of 550 whp on pump gas.
yes that is pump gas, on a built/prepped RB30. 550whp seems reasonable if the wastegate actuator is properly sprung and everything is in order.
Geoff, does full race have these in stock?
We stock the entire line of EFR turbos, the 90 degree comp covers are en route to us
AFAIK, They've only released the 90° housings for the 6258, 6758 and 7163...
100% correct. 8374/9180 already have a vband outlet that can serve as a 90 addition easily
Can't believe I have this turbo and didn't notice that? Do you simply machine off the end and then use a 2.5" vband? Does someone sell a 90 with flanged connection already?
I'd really interested. My piping does fit well but it is all silicone. That outlet really gets tight near my shock tower.
  • Like 1
yes that is correct @harrisracing -- cut the end off and its a standard vband. the same as any Cummins/Holset turbo and many other BW or MHI turbos. There are cast 90 degree vbands available for this application but you could also just but a vband and weld the intercooler pipe to it
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
