hi im wanting to install a wide band o2 sensor for my rb25det and want to know which one is the easyest to install using a power fc? i have seen the LC-1 by innovative motor sports but not sure if its the best choice/ has anyone installed a wide band on there power fc and if so what was required and any pics would be great. did the o2 end up directly giving feed back to the power fc or was the standard narrow band left in as well? just not sure if this can be done so it repaces the factory 02 or if its something else i have to have to monitor while driving, i already have an air/fuel guage watching the current air fuel but if the wide band cannot be installed to replace the standard 02 should i hook the wide band output to the air/fuel guage to watch the more accurate sensor? thanks fo any help.
https://www.sau.com.au/forums/topic/342016-what-wide-band-02-for-power-fc/
yeah if your wideband controller will simulate a narrow band output yes you can. doesn't really make it 'more accurate' as it's still just outputting a narrow band range for the closed loop running.
if it supports narrowband output you can put the signal into the powerfc, its not going to be any more accurate than a new narrow band sensor though as the powerfc does not support wideband O2 sensors.
as a side note, the guages you can buy that tell you what your factory narrow band sensor is outputting are a waste of money and space. any good wideband will have gauge options that you can buy for them that actually tell you something useful and accurate.
oh and another question, would I still require a separate display or can the PFC commander display the AFR somehow?
or alternatievly would I need to run a PDA or laptop with freeware PFC interface software to see live AFRs....?
Nope, as said the PFC doesnt not support Wide Band AFR
You will need a wideband gauge, which usually come with the wideband kit,
I now am tired of typing wideband
AEM i think it is is a wide band kit that i have been looking at getting. I think they are around $250-270 mark?
Its a bit of coin but if you dont trust ya afr's you have or from a recent tune then a good thing for peice fo mind.
I feel the more guages and crap ya have in ya car the more paranoid ya become about everything ya car is saying to you.
Hahhah I spent more time looking at the oil pressure gauge in the Skyline than I did the road lol
well good to see all the feed back. dont realy think i need one now as you only use you narrow or wide band to tune when off throttle (closed loop) when wide open throttle the fc refers back to the tune map, so cant see the point of installing one, and since they tune my care with a wide band sensor as im sure your all aware (as i wasnt), its really no point, correct me if im wrong which i guess i may be as this is just what my tuner has said. i was under the impression the powerfc was always monitoring the narrow band 02 even on full throttle and as a narrow band will only show rich or lean, not how rich or how lean that it may aid my performance on full throttle by installing a wie band 02 sensor giving more accurate a/f ratio to the power fc.
Hello, I just purchased a Techedge 2J wideband, FC Haku, EGT temp thermocouple and a amplifier to bring the output up to 0-5v.
That way I should be able to put both the wide band and temp outputs into the FC HAKU extra inputs and log every thing that happends for a grand total of about $600.00 . I'll update you when it all arrives and I get it working properly.
regards
Chris
  • 8 months later...
thread revival, I have PFC and running with o2 sensors switched off as they are outputting weird values (crap)
I have aem uego wideband kit capable to supplying 0-5v narrowband signal which I was thinking of hooking up as input into PFC
will I need to splice the input into PFC due to running factory twin o2 sensor
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
