  • Replies 55
Trial fitting my Sinco Customs manifold on to the RB30
Hmm, whats the plan for your oil return? Seems like it would be a bit tough running it past the manifold without it touching or getting superheated.
Seems to be more room in Stagea engine bay than Skyline. Will make sure its OK!
I'm noticing that people seem to be spending a lot of time making there engines look pretty. Call me lazy I just wanted the bastard thing running sooner, my car is more like the ugly porn star. It does the job damn well but just a little ghetto at the same time.
Plumbing is arse about face to give enough space for a back seat.
Aiming for 800hp in 15ft - should be fun!
Having trouble uploading more pics 'You did not select a file to upload'???
Edited by roba
Here is my 26/30 going into my black r32
It doesnt look much yet as Im still porting the head.
using
groupA turbos.
550 injectors
2x rb25 afm
extended sump
Ported stock oil pump
lightweight steel flywheel
Just a mild one I will pull the pin at 17psi and 7000 rpm
Just a pic from the top at the moment I just got the covers back
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
