Fitted an SAFC II to the M35 today. I had it lying in my cupboard for the last 2 years, and thought it may come in handy! Only wired it and set it up for now. Need to make a mount and fit it stealth somwhere, then get on the dyno when I have finished the front of the exhaust to tune it.
I was going to post pics of the Greddy boost gauge I got from FR33K, but he sold me a broken/damaged unit :(
Went out today and picked up a nice Defi boost gauge with controller unit II THAT WORKS!
I'll get it installed on Monday hopefully.
Hey gtrwagon
did you contact Aleks before you went and slagged him off in numerous threads?
He's a top bloke and I'm sure he wouldve offered you a refund if you explained the problem
he sells heaps of parts on here and he wouldn't knowingly sell broken shit
dry your eyes,it was only 50 bucks,and if you hadn't of made a twat out of yourself and actually contacted him about it you would gotten your money back I'm sure.you never know,if you man up and contact him you might even still get a refund
pull your head in
Hey gtrwagon
pull your head in
And when did you two start dating? I don't remember asking his bitch for comments? It wasn't $50 it was $60, as I kindly added $10 for postage which he didn't ask for. I have been more than fair waiting 2 weeks for a broken gauge. I don't want my money back either. If he needs $60 so badly as to rip people off, he can keep it. But I have ever right to warn others. Which I will gladly do. Should I go into the PM I sent asking (after waiting a week) would he kindly send it to my work place instead, as I am now back at work, to which I got no reply and it was sent to my house (a week later) and was on my door step when I got home. Yeah, top seller - highly recommended NOT!
Edited by GTRWAGON
I apologize gtrgagon,I feel bad know
Bitch? Hahaha yes,Aleks is a strong yet gentle lover
retard?you Get a boost gauge 'fitted' at a mechanics
you didn't answer my question
did you contact Aleks to let him know there was a problem before you bagged him out?
Maybe couldve been gone about abit better?
lol...... love to know how much u paid for the fitment...
pos neg .... oh and the boost line...
have u tried sucking on the vac line gtrwagon??? i know aleks and he wouldnt sell you shit??
grow up n stop slagging ppl for nothing.
changed the timingbelt on my stag today
Since when is selling someone broken goods nothing?
I know your all a bunch of mates and will stick together cause "he's a good bloke" blah blah blah
But it doesn't change the fact the gauge was broken.
As for paying to get it installed - I have mates too, no charge.
Blizzerd, the 34R rims look sweet! Wish I had the cash to splurge on a set :P
GTRWAGON, I'm sure most of us are reasonable people and would of offered you a refund after a PM. The item might of been broken without his knowledge...
Enough whinging from EVERYONE about this boost gauge or temp bannings will be handed out.
If a dud product is sold, take it up with the seller and see if you can have it sorted out. Future posts on this subject will be treated as if you're slagging a business on here...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
