Thanks for that pick, Nick! I remember you posting it up some time ago and me saving it, but don't remember where it saved.
Chuckie, I might come and have a gander at your's or Bubba's sometime when i'm off cruches!
I'll even take you for a drive.. couple of weeks I should have the LSD in and the adjustable rear upper arms.. then it's skid time! :(
oooh ooohhh let me know too!!!
See above :(
Leaving that till last mikey boy
also need clutch line made up, picking up flywheel next week freshly machined
hopefully get my clutch this week and waiting on my package to rock up containing my sparkly blue dildo shifter
oh and a pair of overalls.....
Hmmm. . . .dildo and overalls togather sounds like things might get a bit messy!!
Hahaha
it's an entry requirment at kidafa's shed
the overalls that is... Not the dildo...
Oh and getting a muffler put on the stag today
I can't handle the sheer awesomeness of just 3inch straight pipes from the turbo back
will try upload a short video later
serviced the stagea tonight at work, fresh oil, new oil filter and new fuel filter. and since we are a wynns stockist i thought i'd do one of there injector power flush kits and a throttle body clean(why not, they were free) and surprise surprise it actually did make a diference.
my stagea used to hold back when pulling between 4500-5250rpm when its really cold, now it pulls nice and smooth all the way to rev cut! sweet!
i so totally should. but i want to experience the stockness and when i get bored il do mods!
you will want to start the next day they need a bit more go in them..this is what i have
turbo tech boost controller $30.00
exhaust i recommend hks silent good sound
nisstune $800.00 +9.psi boost will go to 11 soon
164 rwkw
next is return flow intercooler and 1 day high flow the turbo
this is a video i found on youtube
same exhaust as mine...
almost looks like a green stag too..
love it
today finally finished off the front and rear 50mm wheel studs. didnt take off the hubs, didnt replace footbrake pads.
needed 50mm extended wheel studs to fit wheels over the 13" 324mm Wilwood brake setup.
about to test drive this arvo - flat battery atm, so charging that up, get some air in the brand new unused KU36 semislicks
fill with fresh fuel, give her a beaut wash to get rid of the gumtree crap all over her, and test the brakes/tyres
fs: 10x front 50m wheel studs, 10x rear 50mm wheel studs, suit Stagea S1. front 13.75 knurl, rear 12.75 knurl - $100
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
