I'm sure you'll get whatever you agreed on. I thought scotty might have kept the sump for the VQ35 conversion. Whats the plan, just put another stock back in, or toughen it up a little?
stocky with all my bit's.......TOW it down to VIC.....put it on a dyno and that's it! Then finish off the rest of the car!
New hi flow cat and 3" front pipe going on today to marry up to dump pipe and Legalis exhaust. No more compliance cat & stock pipe! :thumbsup: Powahhhh!
Good stuff Dale! In a couple of weeks you will not even remember how bad the stock lag was :)
New hi flow cat and 3" front pipe going on today to marry up to dump pipe and Legalis exhaust. No more compliance cat & stock pipe! :) Powahhhh!
What front pipe did you get??
I need to do front, cat and dump soon and then hit the drags again :D
Just purchased some 19" GTR LM4 nismo rims for lots of money. and a HDI kit from Hybrid Power international.
add tyres.. almost 5k on rims and an intercooler.
"hides the reciepts from the mrs"
I need to do front, cat and dump soon and then hit the drags again :(
My mechanic is putting it together today, I'm picking it up tomorrow. Pics to follow.
Nice Rims mate, saw them on IM for a little while and was tempted, but couldn't part with the cash! Need picks for sure once their on.
As for the Mrs part- good luck there! :(
Haha my mate suggested i get 5 sets of different locking nuts and just having all different locking nuts on them.
Be left on bricks without them in the city ;)
just started from scratch with the gizzmo EBC. it was boost cutting like a dog on the freeway if i planted it in 4th. the gizzmo was display 1.03 which i stupidly assumed was 10psi or there abouts - given that it was untouched from when i picked it up from previous owner. i was just blaming the boost cut on spiking due to the cold weather. turns out it was reading in BAR and at 1.03 its actually closer to 15psi! no wonder it was throwing out fuel like a BP oil rig, and boost cutting. also not a good idea to run 15psi on stock wheel turbo as far as i'm aware?!
set the gains back to zero and wound the boost back to stock and went from there. now holding a steady 12psi and boosting so much more strongly to red line. i dont think the car was even getting into VCT before boost cutting before!! pretty happy! in defence of previous owner, it was probably setup for tune with the greddy emanage, but given that is unplugged for now i'm happy with my settings.
What settings did you arrive at, duty, gain and spike?
already have that.
Won the motor last night.....now I just have to get it here! Waiting game begins!
Can I borrow your turbo while its all out! I hear these things can seize up if they don't get frequent use :P
i would have to double check, but from memory the duty is at 40, gain i started at 0 and by testing doing 4th gear pulls and then quickly stabbing the throttle into 5th, it was hitting target boost of 12.4 with gain at 30, so i'll leave it there. spike, i have not touched.
if you need help setting one up i found a very helpful and straightforward thread. the actual manual from gizzmo is dribble. i read it 3 times cover to cover and still couldnt work it out!
car pulls a lot more cleanly now. probably not going any harder, but the fact that i can rev it out rather than have it cut at 5k is a plus!
Edited by SMOKEYC34
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
