Did you ask to see if she had working brake lights? If it was me I would've
thats what im annoyed about.. i didnt check and only thought of it after the fact - remembering that i didnt see any.. i spoke to her on the phone and she is going to get the repairer to call me next week when they do the quote.. i might ring them first and ask them to double check the brake lights work. i dont want to risk asking her in case they are broken and she realises and gets them fixed prior.
ok your bumper is easily repaired! not too bad
if it was me, id pay the cash too mate. sorry to hear the bad news. it could have been much worse!
thanks mate .. i agree couldve been much much worse.
apart from that incident the old girl is running really well. got 550kms out of her for the first time ever today . and more left over and i wasnt being shy on the pedal.
after recent alignment and suspension change over. - got a little bit too much damper atm though.. its like damper over kill.
but my business is booming again .. so no big loss. just a bit pissed off at myself after the acco. awell teach me to be more carefull.
glad the business is going well, it allows you to keep the car :)
dont stress about the car.
you got the BC coilovers right? what setting do you have the dampers on?
Mine are midway, 15 clicks I think.
Doesn't matter if her brake lights worked or not. If you hit from behind you are at fault. Six but that is the law.
actually that isnt totally true,
I hit a taxi up the rear and blamed him, they tried using that, but in my case he was changing lanes and between two lanes when impact happened, thus not in a lane and he did not change " when safe to do so".
took forever with insurance thoe,
but hitting somthing up the rear makes life very hard if you want to fight it.
You are taking my comment out of context.... I said if you hit some one from behind and and you are trying to divert blame to them because their brake lights don't work, then you are out of luck.
What you have described is some one not giving way to you in a lane change... very different. As you found out,, hard to prove.
scott has had bigger cups of concrete than you dale :P
Bloody tough crowd here.
With the roads in my area, I'd have snapped my car in half by now with those damper settings
yeah agreed no leg to stand on when rear ending someone. so its probably not going to make a difference.
she made an interesting comment though she goes "- when i was looking in my mirror i saw you were too close" almost an admission of guilt that she was watching me and slammed the brakes on purpose .. but who knows.
bc coil overs ? i wish! .. rsr springs and kyb adjustable dampers ..just got some new ones on the rear.. (and personally i shouldve gotten the coil overs but i had to rego it first ) the shocks are adjustable but they must be on full damper cause its soft as shit rides bumps on the freeway like a boat riding a wave - crazy rebound -
heh dale - they must all have those awesome melbourne /sydney streets.. try qld supposedly the fuel is discounted 10cents a litre for the thousands of dollars extra one has to pay in brakes , suspension and tyres on qld roads which in all honesty are probably one of the worst in the world. Western australia by far has the best roads in this country.. anyone from w.a whos driven on the east coast will agree.
Edited by PetroDola
lol. I haven't fiddled with the dampening since I took the v35 rear springs out. It's a lot stiffer in the back now so perhaps I should have a play around but they aren't too bad...
I can crank it around a corner at nearly full throttle, it stays level, no wheel spin and doesn't step out either, very stable. I don't think I really need the swaybars until I decide an LSD is required and get it on the track.
Gave mine a good clean today and tidied up some bits and pieces over past few days....
Also let the chick iv been with for the past 2 years finally drive it last night haha, shes used to driving a tiny barina and was scared but surprised me, few of my mates cant drive it with the heavy clutch but she was not to bad! Pity over the past 3 weeks we've become no longer an item as she would have been a good deso driver in the stag! see how the next few weeks pans out with us
most stupid law out. whats the point in having break lights then if people arent gonna check them.
I prefer to run the dampers soft, to soak up the bumps (of which there are plenty):angry: rather than use them to limit body roll. And I'm lucky that I have an LSD in mine :nyaanyaa: (about the only extra it came with), It tends toward understeer on the limit; that's why I'm doing the swaybars, I should be able to tune it out, have it cornering flat and still have a fairly cushy ride.
Edited by Daleo
Got a rwc done on my stag today for transferring the rego from nsw to vic. Passed ok but apparently the rear shocks are dying and the front driver side is leaking. Gonna need new suspension soon. Also turbo is leaking oil...lucky it didn't drip on the ground!
There is a good chance it is the rear of the passenger valve cover leaking, not the turbo. I guess you really want to remove it to check though, and highflow it while its out of course. :whistling:
i reckon those shocks are the cause of that noise if its leaking. :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
