change is both inevtiable and good.
I guess I can't talk about what I did to my stagea today in this thread tho.
Change is only good when it fixes the issue. Should have deleted the old chilli thread in my opinion but I guess that doesn't count only being a paid up member...
What was the issue anyway? I see more crap spoken in every other forum, especially the forced and na ones and there is never anything done there, squeaky wheel ey?
I think you could get away with it, the subtitle of this thread states "But you can talk about other stuff too".. What you did to your Stagea today falls into that catagory, so by all means - go at it :P
its a good philosophy to live by. one of mine is, dont shit in your own nest. lol
hows the sump adaptor issue going with proengines?
not going anywhere with them....but it is off being milled this week. not impossible that I will get it back for xmas again. funnily enough i already have a motor to build next week for the race car
may as well tell everyone. yeah i did
a few things to note:
dont ask me how much i paid
dont ask for parts, ill put up a FS post with everything available. If i get a PM from you, you get nothing.
dont assume its yours unless youve paid for it.
thank you :)
gis all ur good bits ;d
*hitches bisbees wreck to the back of the fourby and drags it from zei20I's driveway in the middle of the night*
:ph34r: :ph34r:
Edited by PetroDola
For real. i would of been hella pissed off with proengines. Are you taking legal action? So that must be your track car in your avatar. got a mate deciding on turbos for his atm, probly a pair of 2560R-5's. Of course you must of heard about Powerchip. lmfao
lol -5s, I wish. Its a production car so has to run standard n1 turbos.
unfortunately for me I have a much bigger problem than proengines to take on atm. I'm just getting that one fixed. Hills Motorsport have already pulled the motor, machined the plate and have lined up some new bearings.
:ph34r: :ph34r:
hahah you wish! its a long drive from my place to yours
speaking of which, i have only seen 2 C34s up here and no M35s. sucks to be in surfers. i was hoping to see one on the highway today up to movie world.
are you in town ?
thats only 45 minutes away from my place.
bah shouldve told me.. i wouldve cancelled my appointment and come and visited yah earlier!
Edited by PetroDola
You can.... But no yelling!!!...lol :P
dont worry about chuckie. his bark is bigger than his bite. hows the dads GIO group A car going, if i have that correct?
:O
what did you guys do to our recipe thread?
Ask duncan. lolz
and those bigger problems are race car related i assume. deadlines to meet close to race day? it's good to hear the stagea is getn sorted.
Edited by dirtyRS4
went thought the BusTech factory in QLD today. my wifes cousins own it and surfside buses. awesome to see how a bus is built and all the engineering put into it!
they were churning out 1 bus a day from the factory in the last year.
today i hopped on a sydney government bus that was almost finished, i felt good because i didnt have to pay to get on it :P
Can someone FAST a part number for me? :)
For lack of a better description, Im after the tensioning pulley (or pulley bearing) for the aircon/accessories belt. Mines making 'death noises' :/
i did mine the other month. dont have a part number, but cost me $150 for both belts, i was told take the belt off and get someone to drive you to repco(or similar) and they can match the belt for a fraction of the cost.
EDIT
wait..
Scrap that i just read it! lol
Edited by AaronNM35
Do you mean this (red) one Dunc?
Your just lucky it was on time, and didn't drive straight past you >_<
Once it gets across the border, there is no hope...:dry:
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
