Well I sure showed him! I only filled up half a tank; $1.60 was just a touch too much for a full tank.
I went out to Casino to have a squiz at some drags yesterday and at the servo spent a record (for me) $118 on a tank of 98, ouch pinch.gif . It was about 74L tho.
I filled up for just under $100 for a tank of 98 yesterday. Think that'll be my last time filling up at United, apparently they're dropping the Premium 100 10% ethanol juice because they've had issues from the Queensland floods.
Looks like the guys that did your exhaust have started producing; http://www.ebay.com.au/itm/NISSAN-STAGEA-250T-RS4-M35-TURBO-DUMP-FRONT-PIPE-/330566818023?pt=AU_Car_Parts_Accessories&hash=item4cf75158e7
Looks nice, maybe a bit of a tight bend off the back of the turbo though. The split dump might make it a bit of a PITA to wrap, did you have yours coated or wrapped?
What were they charging for the rest of the system?
Hmm interesting.
No, I didn't have mine coated or wrapped yet, left everything up to Andrew so far. I'm guessing it hasn't been wrapped, so I'll be adding that to the ever expanding list.
Not sure what they're charging for the rest of the system, I'll call him tomorrow and check. Waiting to post it here!
Haha atleast when you fill up you don't get yelled at by the caltex attendant saying "no no don't put ethanol in your car it won't work I don't care what you say" true story happened today lol
I get this everytime I fill up at Springvale...LOL
what a sham! he probably said that so youd fill right up.
AAron, thats gold! did you spin all 4 wheels right out of the station to show him that you CAN put E85 in your car?
ass hole with your Nismo.
lol shuttup.. even then it only goes up to like 54% till about 4500.. then once it completely opens my boost creep issue takes over and 22psi later the engine cuts lol..
f**k i need a nismo..
Was there a cloaking device optioned on the series 1? I suspected there might be because of how we've avoided any police scrutiny in the last couple of years driving it.
It was confirmed this morning when a woman ran into the back of it at an intersection, she apparently "thought we'd gone". 40 minutes later it was reconfirmed; on the way to a panel beaters for a quote I pulled over on the concrete apron of a factory carpark to get my directions, and as I began to move again guy reversed his flat tray falcon into the side of it.
Can it be turned off?
Edited by floody
lol.
not just a stagea option, our 350z used to have it too.
6 reasonable hits in 5 years, all not at fault. highlights included an l plater driving into the passenger door, and a truck running into it and pushing it off parramatta rd onto the footpath
Given the shitstorm in the SA section ( http://www.skylinesaustralia.com/forums/topic/365288-ch10-news-and-the-tunnel/) thanks to some retarded skyline drivers Im bloody glad I drive a volvo and its going to be off the road for a couple of weeks any how :domokun:
thread is gone. im guessing something attached to SAU that they have removed evidence of? lol
That thread was a discussion about the news item that stemmed from the video posted here http://www.skylinesaustralia.com/forums/topic/364430-mini-cruz-thru-hills/ :rolleyes:
Thats what you think... Now where did i leave those keys... :whistling:
Whats with you and trying to steal my car, parts off my car, and even parts I'm yet to fit to my car? :P Must be something in the water out north :whistling::nyaanyaa:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
