lol yeh but your mature..
im 21. lol
i think i made the good choice in selling it.. getting this power bug and hoon bug out of me while im young. instead of still having it while I have a family *coughscottcough* but yeh.
once I calm down a bit I'll definitely get another stag.
im 21. lol
Lol @ growing out of it...:whistling:
37 and I'm worse than I ever was.
Mainly because I can fund my addiction now...
F**k going slow; that's for pussies.
Edited by Daleo
so true, now we can afford mods we dont have to dream about them anymore
lol yeh your probably right. but i needed something light,with alot of response which my stag had none of.
i dont exactly regret selling the stag, but will definitely be getting back into one.. its an affordable modern performance car to take anyone and anything in.
what more would you want?
Response; You need a sidedraft Weber fed 4cyl that revs to at least 8000rpm. Everyone does.:thumbsup:
Just sayin'
if anyones interested, here are a few pics from the weekend.
So, did you have a good time in the bush eating dust? Looks like a bit of fun.
Nikon D700, depending on my location to the subject, either a 24-70 or 70-200. i prefer the 70-200 as its a friggen kick ass lens
the last one is a bit blurry, i started to turn my back to the car as you get covered in pebbles as it goes past
Edited by zei20l
Is the 70-200 a 2.8? Canon's 70-200 2.8 L is regarded as one of their best lenses. Brilliant bit of gear.
yeah its F2.8, i rekon one of nikon's best lenses lol
good for pretty much anything except where you need wide angle
I love my 70-200mm f/2.8L, I just wish it wasn't so damned heavy. (I'm a skinny mofo, by the way...)
My favourite lens, though, is the 17-55mm f/2.8 - all it really needs to be an L-series lens is weather sealing and the red ring.
Do you have the 2.8 IS?
The last lens I bought was the sigma 17-50 2.8. Magic bit of glass and substantially cheaper than the canon.
Which one, Ryan - the 70-200mm or the 17-55mm? The 17-55mm has, but unfortunately the 70-200mm doesn't. :(
i just bought a SLR on the weekend :) its a olympus pen e-pl2........... dont know much about SLR camera's yet thought LOL
it came with dual lens's a 14-42mm zuiko 37* and a 40-150mm zuiko 37*
and its freaken light (and compact) only weighs 979grams............ thats the bag, camera and both lens's
I wouldnt worry about that. Some mates were trying to convince me I didnt need a 70-200 2.8 IS, so leant me a non IS. Brilliant bit of glass. My next purchase for sure.
Seen those, look nice. Although considering how small and light it is Id ditch the lenses and get a nice flexible zoom lens.
All this camera talk has made ne horny!
Youre a sick man Craig... Go talk to your wife then!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
