For the Nismo awesome club- Not really an ideal fitment, but better than stock. good if your std height. Cheap too!
http://www.nissanusa...30S-RNA4010.jsp
mmm.. they are nice and good value.. :)
they are big enough for me
next time it will be larger rolling diameter tyres
Never met a bloke who'd say no to an extra inch...:ph34r:
Edited by Daleo
nah i wont make it there, but i know one of the guys filming it!
tonight, gave jetwreck a hand doing a shift kit to a 350z. fck me did it shift fast!!! and every push of the + and - performed a gear change.
anyway, the owner was VERY happy with the outcome. as you would be.
removed my front prop shaft, car feels better in corners i rekon!
yeh the series 2 valve bodies are already upgraded.
the gear box also rev matches and does all this extra funky shit.
My sisters one is auto and actually chirps second on change, and its amazing and holding revs going down gears.
So, we have a separate gearbox computer right?
Is there any way it would work to swap with the 350z one despite the 2wd/4wd difference?
I would love it if mine changed exactly when I wanted not when it decided it felt like doing it.....
the Trans ecu's in the two cars talk to the Cars main ecu. so i dont think going from auto 4wd to auto 2wd would work.
going to Manual 2wd on the other hand, should be no problem. as long as the car can be tuned(emanage f-con etc) you should be fine!
but you also have to keep in mind that the 350z is a lighter car, so some of the feel maybe in that.
its funny you mentioned that, i already thought of obtaining a V35 or Z33 TCU and seeing what would happen. Id say a V35 one would be more compatible (within the same years) and may have different programming.
i know the two TCUs i have are slightly different. i might put back my other one
it lightens the drivetrain taking out the front drive shaft. gear changes ARE snappier on mine now
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
