I assume someones looking to buy this and repair it. http://www.ebay.com.au/itm/NISSAN-STAGEA-AR-X-2001-M35-WAGON-2-5L-TURBO-DAMAGE-R34-LIGHT-DAMAGE-REPAIR-/320826813759?pt=AU_Cars&hash=item4ab2c4ad3f#ht_968wt_1163
I recall that one going to Pickles some time ago, I guess it didnt sell or whoever bought it couldn't fix it for what the deemed an acceptable profit?
I assume someones looking to buy this and repair it. http://www.ebay.com....f#ht_968wt_1163
This was on Ebay last year, he wanted somewhere at least $6500, obviously it was a little ambitious.whistling.gif
Originally, he was making out that it was only a couple of grand to repair; which we all know is basically bollocks.
Also, the rules have changed in NSW, so if a NSW buyer wanted it; this is basically a no-go unless you want to strip it.
Basically anything thats been declared write off (even if only for financial reasons) cant be re-registered in NSW, is that correct?
SA still allows for financial write offs to be re-registered, but if it has any structural damage it'll never be road registerable.
$6.5k? You can buy a whole new Stagea for somewhere around $12k these days! Very ambitious. Its definitely a bit of work requried to get it back on the road, and theres a signficiant lead time in sourcing the parts (all has to come via sea). Definitely not a small project or one for the uninformed. Plus axis front ends are a bit more scarse to come by 2nd hand, likewise with the guards.
Less damage and kms that were on my car... but less mods too.
Only just slightly less than yours! Looks like it has an exhaust of some description, but no idea about the car other than that.
Yeah, I'm pretty sure that's the case; I have a couple of mates who buy damaged RWO (repairable write off) bikes and repair them, they've basically stopped now.
HAS HAD AN ADDITIONAL "SENTINEL WARRANTY PLAN" TAKEN OUT ON THE VEHICLE FOR 60 MONTHS FROM DATE OF PURCHASE
Erm... would you really expect them to honour the warranty now?
i love that he said:
WOULD HAVE TO BE ONE OF THE BEST KEPT STAGEA'S AROUND
Yeah doesnt really look like it!
it will be good for parts, or to strip out and turn into a track car!
i'll put dibbs on the chrome out of the front bar if anyone buys the car!!!!
Lol, except for the front left corner being smashed to shit...
Who's stripping an AXIS for the track; you might as well start with one of these...
Edited by Daleo
Is the owner of this car on SAU?
Didn't someone dinged his AXIS a few months ago?
I dont think they're on here. That car has been off the road for a while. I think Angus Smart posted about it when it was up for sale last time. You might be thinking of the silver Axis that went through pickles 6 or so months ago, that was up on M35Stagea.info for discussion. Went for over 3k at auction iirc
This axis has been on fleabay a few times now. Last time it was towards the end of last year and it did sell. I assume the buyer didn't end up paying as its the same guy listing it for sale again. I can't remember what it did sell for though. This seller must buy a lot of repairable write off cars from auction and try to on sell on fleabay for a quick profit. He has a heap of cars for auction and all apparently needing stuff all work.
Well it seems my old stagea has officially been written off.
Suggest all the SA lads keep an eye on the auctions and local wreckers.
Might be able to score yourselves some dayz carbon accessories and kit.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
