"Medieval times of the many 50 seaming machine it is in the midst of part many exhibiting to in addition to."
God I love the Google translations of IM! Constant source of entertainment!
Love it, but I don't think IM use Google to translate on their site.
You will get a different translation if you cut the auction portion of the url out of the address bar and put it into Google Translate (or just into the address bar in a new tab if using Chrome).
wow. loads of hours gone into Uni this week. 7x lectures to write out into revision note books takes a long time!
throw in practicals/tutorials/workshop assignments & Ive got it cut out for me !!! doing well though, and importantly Im enjoying it.
bloody brake line. had front braided lines made up Dec last year, today found front left has split where it screws into the caliper.
the line is like 40cm long - how long should it be? I reckon it is 2inches too long.
its obviously too long as it has bent itself into a right angle at the caliper fixture for some reason, and the metal fitting (joining line to banjo) has rubbed on the compressed line. not happy - dont really have the time to waste on it.
Good to hear your course is going well Brendan, was a gutsy move to go and do something completely different.
Best of luck mate; amazing how much easier it is to knuckle down & do the study when you actually enjoy the subject matter.thumbsup.gif
As for your lines; the last ADR approved braided lines I had made; had a short rubber sleeve crimped into the swage; to prevent exactly what you're talking about.
Do you have an OEM to use as a sample?
Thank you dale!
Yes its a huge challenge - Im not exactly a 'sciency' type but I'll be trying to put in my best efforts. Very tiring, but Im enjoying applying myself to the task Ive set for myself; we'll see where it goes. Ive got my goal, a vision, and need to work at the little weekly steps in getting there.
I noticed the lines that were made up (ADR approved) uses a metal sleeve instead of the rubber sleeve. On full lock over a speedbump or spoondrain it must be knocking against the swaybar link bracket, or thereabouts. Looks like I'll have a pair of custom banjo-type lines made up end of this week, to lose that 1.5inches that protudes out of the caliper with screw-in type lines. Must be a space/fitment issue due to the caliper brackets and 322mm discs I run; obviously puts everything out of kilter compared to the stock setup.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
