"Medieval times of the many 50 seaming machine it is in the midst of part many exhibiting to in addition to."
God I love the Google translations of IM! Constant source of entertainment!
Love it, but I don't think IM use Google to translate on their site.
You will get a different translation if you cut the auction portion of the url out of the address bar and put it into Google Translate (or just into the address bar in a new tab if using Chrome).
wow. loads of hours gone into Uni this week. 7x lectures to write out into revision note books takes a long time!
throw in practicals/tutorials/workshop assignments & Ive got it cut out for me !!! doing well though, and importantly Im enjoying it.
bloody brake line. had front braided lines made up Dec last year, today found front left has split where it screws into the caliper.
the line is like 40cm long - how long should it be? I reckon it is 2inches too long.
its obviously too long as it has bent itself into a right angle at the caliper fixture for some reason, and the metal fitting (joining line to banjo) has rubbed on the compressed line. not happy - dont really have the time to waste on it.
Good to hear your course is going well Brendan, was a gutsy move to go and do something completely different.
Best of luck mate; amazing how much easier it is to knuckle down & do the study when you actually enjoy the subject matter.thumbsup.gif
As for your lines; the last ADR approved braided lines I had made; had a short rubber sleeve crimped into the swage; to prevent exactly what you're talking about.
Do you have an OEM to use as a sample?
Thank you dale!
Yes its a huge challenge - Im not exactly a 'sciency' type but I'll be trying to put in my best efforts. Very tiring, but Im enjoying applying myself to the task Ive set for myself; we'll see where it goes. Ive got my goal, a vision, and need to work at the little weekly steps in getting there.
I noticed the lines that were made up (ADR approved) uses a metal sleeve instead of the rubber sleeve. On full lock over a speedbump or spoondrain it must be knocking against the swaybar link bracket, or thereabouts. Looks like I'll have a pair of custom banjo-type lines made up end of this week, to lose that 1.5inches that protudes out of the caliper with screw-in type lines. Must be a space/fitment issue due to the caliper brackets and 322mm discs I run; obviously puts everything out of kilter compared to the stock setup.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
