Big big wet has come to the southeast Everyone safe? Evacuated, or flooded?
Nice....but it won't go with aaalllll the other bits I have coming! Plus that's not part of the widebody Nismo kit! ;p
Takero's (?) front bar Craig - surely that will match some of the bits coming? Just needs paint..... :whistling:
yummy
i'd be happy with just a front lip & side skirts...
contemplating whether i should get the skirts for sale on ebay
There's more then one nismo kit for our cars?
I thought this one was it?
Nope, just one Nismo kit for NM's and one for PM's.
They are only "widebody" if you modify them to be and are made for RS/RX's only
Yes
mmmm.... Takero's ricey goodness
Interesting...got a pic?
Yes
concur...bit OTT riceness...
Damn you!
Don't won't front bar but the back looks like porn IMO!
1331192222[/url]' post='6266681']
Ahh, just heaps of awesome wagon action; hard to explain, coupe owners wouldn't understand...nyaanyaa.gif
Haha same old shit.. Given up on cars for the time being so just driving around the Jaffa
1331208343[/url]' post='6267141']
No gay s14 shit bro from another mo!
We have the speed and handling...just working on aero!
2 tonne of our of control goodness!
haha I hear your getting a wide body? I thought stags already have that
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
