lol im pretty sure the genuine bugeye STI WRX that did a run has a semi forged bottom end and all this extra crap and still only pulled 130 at the wheels.
hands down out of a WRC class I would be going an evo.
bang for buck! if you like the go kart feel.
lol mine feels like a trolley than a go kart. Scott knows what I mean :P
Yeah I like evos...exxxy though...
STI's come with forged internals anyway...its not like it cost him extra....but 130awkw? wtf...
Edited by ironpaw
Haven't really driven any of those little 4 doors. I had a quick blat in a 22B, but not long enough to tell anything about them except LAGGGGGG. Oh, and a GT3037 Evo, but same thing, punched the throttle and got to 3500 and still nothing before I ran outta space.
But really, they are a tool for going quick (targa/track) especially the Evo. They don't "feel" the same as a Nissan or Mazda. They come from more economical backgrounds- shopping trolley stock. If you are dead set serious about motorsport, then I'd get an evo. But if its a daily, or combined duties car, then you can't beat what you got. Plus all the other owners are just so cool.
A guy had built his motor using all cosworth forged parts. Supposedly cost him over $30,000.00 just for the motor.
He was 'thrashing the f**k out of it' on the way to the dyno. Cihan ran it on the dyno and after about 3500rpm the AFR shot up to about 16 or 17 before cihan took his foot off.
Would not have been a pretty sight to see that thing blow up
  • 4 weeks later...
lol, turbo won't be for a while. Want to get the other stuff sorted first.
Like supercharger? :P
Sounds good mate. Look forward to seeing pics when it's in your ownership, and progress on your plans!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
