I can help with your addiction... :)
I would prescribe another 100kw to put that smile back on your face, but power costs money and lots of it. (as i'm sure your gtr mate has found out.) And you cant control what you have now... Back driving yet? :P
Another month and and half...almost...there...LOL
Even if I was pushing 350awkw I'm sure it won't have the same "feel" as a 350awkw GTR/Evo/WRX/etc etc...heck I've been in an Audi R8 (300kw?) and I'm sure that thing would rape a 400kw Nm35.
The 2 tonne weight and the gimped throttle (even if wire cut) is teh ghey.
Ah well can't have it all. Unless I start saving for a weekend car :P
Edited by ironpaw
The response is the killer with these, I drove an Evo 8 yesterday; I'd kill to have that kind of throttle response. Not so sure about the Police attention (or the woeful wing) though; I like my "invisible" wagon.
2tonnes? I weighbridged mine at 1680kg.
Just realised why I do everything myself on my car - fing auto shops are as helpful as a kick up the balls.
went to a jax shop to enquire about some centre caps - had the measurement and everything. All he could say was you should try the wheel company email them or whatever. Didn't want to help at all. To busy selling shit wheels to commodore owners I guess.
Anyone know anywhere I can find some plain jane centre caps with a 79.5mm centrebore, with a decent (over 15mm) clearance over the bolt?
SSR US want $40 each for SSR ones :(
Nope, just have a centre bore of 79.5 mm, fit obviously, have a decent depth to fit over the hub bolt, and not look ghey- nice and plain so I can spray black and shove them on
The SSR ones look a work of art - turned aluminium or something I think, but are also shiny, and I don't really want shiny, and I don't really want to pay $40us each + postage to spray em black!
numbah 4
Dunno if Iain can still grab one to try, but maybe you could see if the centre caps of the Nismo LMX5 rim would fit?
They looked nice but pushed in to the rim so may not fit other rims. I don't know how yours are attached.
Nah, I'd say the LMX5 centre bore is way too small. EVERYTHING I have tried has been too small, Craigs, varrstoens, stocks etc.
Just need to suck it up and buy some 2 mins noodles to live off for the next fortnight :P
Holy crap! I stripped everything loose out of mine (sub, spare wheel, tool kit, rear ashtray) to get to 'drag weight' & weighbridge came in at 1800kg. Curse you luxury (shakes fist in air for effect).
Having another look at theirs I can see, looks like it'd be hard to replicate the ssr. There is a rubber o ring and everything in the base of them. I can't quite tell how they seat, but the wheels so have a little lip in them. It's a mystery.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
