Who knows where their going to put a T62R in that engine bay, but if you make enough space I guess where the airbox sits.
I always thought the airbox was overrated any how.
Needs to be rotated 90 degrees, add some creative exhaust manifolds and an inlet track that puts the pod outside the engine bay... then ceramic coat everything!
Would be able to run a radiator and air con then.
I'm more interested in the gearbox. Looks like an R34 GTR box. Not sure what is custom to make it fit, besides the gearbox crossmember?
Also, is the extended sump really necessary on these things, or are they just doing it out of habit/experience with other motors?
The r34 box needs extensive mods to fit Ryan, custom cut and shut bellhousing, major floor pan modification, custom gearbox mounts etc. I would say there is an easy 20k blown there at least.
The extended sump is only needed for the oil return, my car was fine at the track oil pickup wise, so our stock setup works very well.
Didn't look like the bell housing had been cut and shut to my untrained eye though?
Not that I have a trained eye by any stretch, nor do I know the GTR gearbox design.. but is that actually a factor weld?
The best chance we had was the 350z guy who went AWD, he was planning to cad the bellhousing and sell an AWD kit for the 34 box. Costs were too high unfortunately. RWD should be easy with a V35 manual halfcut. Still looking for one though...
Costs to CAD it were too high?
So he didn't finish his AWD conversion, or he did but the kits worked out too expensive?
Hows your conversion going Scott? Thought you'd be doing RWD skids by now...
He finished his, just the parts would cost too much to replicate.
I need to find a V35 halfcut first Ryan, do you have one? :P
(The auto is being strengthened some more, I should have it back on the road next week.)
What do you need off the V35? Do you really need the whole halfcut?
EDIT: Don't we have a thread that we're supposed to discuss this shit in? :P
Hello Gents.
Just so happens I had a little conversation with the Owner of Mercury Motorsport at the SAU nats about this car, and found out some details. I'll read the rest of the thread, since I've been gone and fill in the blanks.
Ok, so, I'll give some general info, because I know the owner still pokes round these parts, so no numbers or anything in his respect.
The owner would like it to be a daily driver, but I think it will turn out a weekend car. He was thinking of going t51, but once the t62 was looked at, change was made.
So, the motor is a crate motor from gtm in the US. Basically mercury told him to "tick every option box" when building the motor. Took 4 months to get here. Cost a lot of money.
We all know about the gearbox. They will use the stock attesa pump system to run the transfer case.
Front and rear diffs are yet to be decided on, but LSDs will be used.
The turbo will sit off custom made exhaust manifolds, point forwards tucked under the front reo. This will require a custom radiator. Owner wants to retain AC, but I think realistically the AC will be deleted.
A new p/s engine mount will be fabricated to clear the manifold, and dump.
Obviously external gate or some kind.
Ecu will be a haltech platinum pro ps2000. Maybe with a custom dash.
Owner bought the intake plenum.
So all in all, this is a serious investment on behalf of the owner. Once the teething issues are sorted out, which there will invariably be, this will represent the craziest M35 worldwide.
I hope the owner doesn't mind me posting, but I think we should all be able to share in his excitement about this build.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
