Hmm.... what to get... a quick Mitsu..
Evo or VR4 Galant.... :whistling:
Na sod it, I'm an AR-X owner and proud to drive on stilts...
So that will be...
Territory Turbo.... :devil:
good to see there is still a VQ keeping that garage from being totally gaids.
Quiet in here today. people must be doing family shit eh?
Yeah, Evan & I have been cruising on our bikes; but we had a storm & had to come home.
Now he's recovering the ammo after a Nerf war...
There used to be two VQ's in there :(
  • 3 weeks later...
Hey guys, just wanted to get some feedback on something I came across yesterday.
Went to check out a S2 Stagea in a local wreckers, was quoted $1500 for manual conversion kit. Box, clutch, pedals & handbrake.
I think this is reasonable, but would appreciate any comments.
Cheers,
Ian
yeah if that is complete (ie including console etc) it is a reasonable price. Could probably be done cheaper if you want to stuff around collecting all the bits seperately, but that could take a while
Console was an auto hack job, might take it and see if I can make one out of fibre glass, better still fix the hack job one with fibre glass so I dont have to destroy my own.
Hopefully I'll have this early next week at the latest, then the fun begins
In the words of the late BIG KEV - "I'm excited"
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
