custom sub box fits 2 X 12 inches in between the strut towers very snugly
amp goes in spare tyre hole, its a big amp :P
oh sweet did you get it made for you?? cost much? i'm looking to get one made to fit snugly behind the seats between the struts aswell!
as my currently enclosure I bought doesnt fit properly :(
haha and who needs a spare tyre when u got BASSSSsss :)
Brett @ Performance Car audio:
http://www.performancecaraudio.com.au/
If we have a stagea meet your more than welcome to measure up my setup if you want, it shouldnt be too hard to make, just made out of some MDF i assume :P
and yep no need for a spare wheel when you have bass, that and it would f**k up my 4wd system if i ever put it on :P
hahah I call my spare wheel "teh cheese cutter"
oh stag meet i'm in on that :D (DAMN SHE'S DIRTY ATM)
haha last one I was in studio.. but that's all pretty much done now... just a few more sessions!
what i'm thinking is reboxxing my 10" type R Alpine into a enclosure that fits in there nicely, but leaves me all the room i already have for my band gear... then mounting an amp on the side of it!.. :)
nope
just need to make sure you stop in on the forums so you know when its on :)
...and make sure you don't act like an attention-grabbing idiot while out on the road. SAU has a pretty good reputation across the country, we don't need people ruining that.
:D
:D
+1
hey guys,
i'm pretty sure i've got a slight leak from the round black oil reservior on the right of my engine..
it has been fine after i got it serviced but its doing this grinding whining noise coming from my power steering again haha :(
what sort of oil do i need to put into it ?? :) just gonna keep topping it up til i get it fixed!
Tomas
hey guys,
Tomas
ok it should be Dextron 3 :) couldn't find the info on here for some odd reason whistling.gif probably cos i'm a n00bdomokun.gif
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
