  • Replies 317
Posted Images
Kory, now I relook at that photo the water and bank is way to saturated and the tower thing is too underexposed. I don't spend enough time processing my shots, I gotta stop being lazy! Also the laptop in front of the TV isn't the best tool to use.
Post up that pic, Zennon. She wouldn't let me take a decent photo of her, so I had to make the most of the one horrible photo I could get.
I need to know which one is better!!! Decide for me!! I'm thinking the 1st one.
This one, Kory - although the blurred trees in the second shot add to the sense of speed, they're distracting to me.
Nick, if you want more light painting 'training' i'll let you know next time i'm heading out to do some. you can come along and i'll show you some more/give you some more practice. Or we could experiment on the stag. it's a challenging colour. actually... i like that idea more. let's get together and work out how to best light your stag. hahaha that sounds dirty as.
Matt, that sounds awesome. Seeing as my car is a very dark green, and the location had very little light, I'm thinking we use Bulb mode and go for maybe 40-45 seconds and see if it comes out better. I've already got a remote cable release for my camera, and the camera has a time display on the screen (as I'm sure most would) to tell you how long the shutter's been open.
Jay I'm jealous. i wanna ride through the city taking shots all day :)
dont be, so far ive estimated my income will be around the $200-$250 mark each week, lol.
i reckon i would be better off staying on the dole, haha.
but, back on topic...
hmmmm. obsessed by a number much?
a quick shot in the Brookman building at UniSA. the squeaky staircase freaked me out, didnt sound too safe, haha. i should get some pics of the woodwork too next time im there. such awesome craftsmanship, something thats lacking a bit in buildings these days.
pity about the blowouts on the left hand side. but meh, its a point and shoot, what can you do, lol.
if your keen, this is where i keep uploading pics taken during the day (public link, you dont need facebook)
http://www.facebook.com/album.php?aid=2071...mp;l=24f11db5f3
will save me spamming this thread all the time, lol.
As promised :)
You would think so wouldn't you! How hard could it be! *sigh*
Edited by ZENNON
is knowing how long the shutter has been open really important for light painting pics tho, specially when using bulb? in my case it is as the shutter will close at a specific time, but if it was on bulb i would be loving it as it would give me the chance to worry more about being accurate and complete rather than rushing to get everything done in a pre-determined amount of time.
Hi,
Got a perfect condition canon 70-200 F4 IS L lens. Its very sharp, and an incredible lens to own. Im slowly moving away from using this lens so hense why its up for sale.
Price: $1150 firm.
Contact: 0423180545 or pm me here.
Purchased last year sometime (cant remember when, will have to check invoice tonight).
No scratches etc.. No fungus.. perfect condition.
Will take some pics soon.
Thanks,
Not I don't actually light paint - just really annoying how my camera doesn't show how long shutter has been open for when doing long exposures
Having said that it is about the only thing I don't like about my camera (and only an problem when doing night time shooting or using the 10-stop ND filter)
FS Canon 70-200 F4 IS L
Seems like a good post for the chat thread - or better yet its own thread! :verymad:
Edited by ZENNON
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
