No...... That  is not the version fitted to R32's.
They were a (very ugly) generic version with NISSAN printed on the back.
Trust me you don't want them.
They needed to be cut to fit, bloody horrible things.
Photo attached.
  • 3 weeks later...
5 hours ago, RB26DETT 240Z said:
https://www.shannons.com.au/auctions/2017-shannons-sydney-autumn-classic-auction/UC9L6FAOD8X733FX/
So the red ADM r32 gtr went 91k Anyone on these forums picked it up?
Not sure, but I was there -
Cheers...... Bob.
  • Like 4
  • 1 month later...
On 07/06/2017 at 1:54 PM, 21PC said:
Apparently Jun II's running gear has been swapped into a JDM shell and the original Black ADM is being restored
If this is true, it hasn't been done as yet as I did see a recent clip of this and was still an ADM shell
3 hours ago, Aussie_Delivered_R32_GTR said:
Wow..... Just found this......
This is a great share. I enjoyed watching this...i too think that the 32 is undervalued, compare it to the 911 which was ~33% more expensive than the 32 at the time, yet the 911 now fetches up to 300k!!!
Edited by Marko R1
This is one example video of a run done this month. They still used a black shell but you can see there are no ADM bits such as rear taillights which were on the previous shell. Think Andrew from Motive DVD said it also somewhere that I can't remember at the moment.
  • Like 1
  • 3 weeks later...
PLEASE KEEP THIS THREAD CLEAN - LEAST CHAT AS POSSIBLE, ADMIN WILL REMOVE WITHOUT WARNING
This is the thread for the Australian delivered GTR's.
Im not sure of the format we would like or what info we should share. I throw up what I thinks fair, each user can do their own thing.
Colour: Wine red mica
Delivered: August 91
Sold: 10/11/92
Number: 68 of 100 (16907)
KMS: 97800 (books)
Dealership: Alf Barbagallo Nissan WA
Owners: 3
Purchased: Jan 08
Locale: Sunshine Coast QLD.
Currently the car is stock apart from the exhaust, stereo (have original), steering wheel (have original) and side indicators.
Cheers,
Ken
Delivered: May 91
Sold: 1992
Number: 28 of 100 (16075)
KMS: 53, 000
Dealership: Col Crawfords Brookvale. Sydney
Owners: 1
Purchased: 1992
Locale: Sydney.
Bought as a ..."Demo" ...with 7kms on the clock from Col Crawford's Brookvale for $85,000 . This car has original exhaust, radio and front bar in storage. Had a Nismo exhaust Dealer fitted at the time. It has been stolen 3 times and lost several badges to the screwdriver fairies. Has a factory warranty replacement engine fitted (Vspec), although engine running as non vspec7e61cf14bf18ddfdee8044895e3ba3f8.jpg9f58d75cfc027982cfd678263bde2dc0.jpg
  • Like 1
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
