No...... That  is not the version fitted to R32's.
They were a (very ugly) generic version with NISSAN printed on the back.
Trust me you don't want them.
They needed to be cut to fit, bloody horrible things.
Photo attached.
  • 3 weeks later...
5 hours ago, RB26DETT 240Z said:
https://www.shannons.com.au/auctions/2017-shannons-sydney-autumn-classic-auction/UC9L6FAOD8X733FX/
So the red ADM r32 gtr went 91k Anyone on these forums picked it up?
Not sure, but I was there -
Cheers...... Bob.
  • Like 4
  • 1 month later...
On 07/06/2017 at 1:54 PM, 21PC said:
Apparently Jun II's running gear has been swapped into a JDM shell and the original Black ADM is being restored
If this is true, it hasn't been done as yet as I did see a recent clip of this and was still an ADM shell
3 hours ago, Aussie_Delivered_R32_GTR said:
Wow..... Just found this......
This is a great share. I enjoyed watching this...i too think that the 32 is undervalued, compare it to the 911 which was ~33% more expensive than the 32 at the time, yet the 911 now fetches up to 300k!!!
Edited by Marko R1
This is one example video of a run done this month. They still used a black shell but you can see there are no ADM bits such as rear taillights which were on the previous shell. Think Andrew from Motive DVD said it also somewhere that I can't remember at the moment.
  • Like 1
  • 3 weeks later...
PLEASE KEEP THIS THREAD CLEAN - LEAST CHAT AS POSSIBLE, ADMIN WILL REMOVE WITHOUT WARNING
This is the thread for the Australian delivered GTR's.
Im not sure of the format we would like or what info we should share. I throw up what I thinks fair, each user can do their own thing.
Colour: Wine red mica
Delivered: August 91
Sold: 10/11/92
Number: 68 of 100 (16907)
KMS: 97800 (books)
Dealership: Alf Barbagallo Nissan WA
Owners: 3
Purchased: Jan 08
Locale: Sunshine Coast QLD.
Currently the car is stock apart from the exhaust, stereo (have original), steering wheel (have original) and side indicators.
Cheers,
Ken
Delivered: May 91
Sold: 1992
Number: 28 of 100 (16075)
KMS: 53, 000
Dealership: Col Crawfords Brookvale. Sydney
Owners: 1
Purchased: 1992
Locale: Sydney.
Bought as a ..."Demo" ...with 7kms on the clock from Col Crawford's Brookvale for $85,000 . This car has original exhaust, radio and front bar in storage. Had a Nismo exhaust Dealer fitted at the time. It has been stolen 3 times and lost several badges to the screwdriver fairies. Has a factory warranty replacement engine fitted (Vspec), although engine running as non vspec7e61cf14bf18ddfdee8044895e3ba3f8.jpg9f58d75cfc027982cfd678263bde2dc0.jpg
  • Like 1
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
