  • 2 months later...
The black is build number 98 and I too haven't seen it before.
The silver car is #8 as the plate suggests. This car has done the rounds in our discussions before. Originally in Adelaide then went to Melbourne. Low mileage car but no documentation to validate at time of sale. Did it look like a sub 40,000km car? Shame I missed it. It must have arrived late.
The red one next to it is a lovely car, previously owned by my mate, I know it well.
Cheers,
Bob.
I didn't get to see the red or silver. They came later. What time were you there I had taken my car but must have missed you there also. The black car was apparently rough and probably has had a respray and the engine bay is apparently rough as. Fourth ADM I know being restored. Seems like the value is high enough for people to start restoring them. Obviously many have been driven and enjoyed
Edited by 21PC
Hi all
Haven’t had a chance to introduce my self my name is George and I’m the new owner of the black build #98
I was hoping to catch up with a few other ADM owners over the weekend,but was at my other car most of the time blue R34 number plate WPN R34
I bought the car aprx a month ago and it has all books receipts etc with it
I was told the car sat for aprx 5 years and wasn’t driven much at all, yes in the bay they have replaced the factory intercooler and radiator with after market items.
I have all the factory items and the car will be going in for all resto work in aprx a weeks time.
I will have a load of questions regarding the work loll
Would be good to catch up with someone for advice and help.
Cheers.
  • Like 1
In my opinion it's a great car and a good purchase George. Welcome btw. I'm hearing this as second hand info and from my quick lookover at the festval I think it's a neat car you can actually drive. Controversial opinion on an ADM I actually don't mind the rims also ?. Got more details e.g interstate purchase, KMs etc?
#28 ADM GTR owner (my dad) is contemplating selling his car. He has had it stolen/badged to many times. Recently an attempt to steal it was the final straw. He has had an offer. Has lived under a cover most of its life. Has a few dents here and there drivers seat as wear in usual place. Has original front bar, and exhaust system which were swapped at Nissan for N1 and Nismo 3in. Loads more. Any interest or prices he should be looking fortapatalk_1527634978341.jpeg20170721_190003.jpeg20170722_092611.jpeg
Photos this weekend. Mileage around 53,000km. Has original books and radio also. Was purchased from Col Crawsfords. Has a warranty replaced VSpec engine fitted by Rockdale Nissan due to loss of compression in rear 2 cylinders that was changed around 25,000km mark
Is your dads car parked on the street in the St George area (I wont mention the suburb here hehe)? I'm a local to this area and I did see one parked on the street about 8mths ago or so and I thought to myself "there is no way I'd leave mine on the street like that" :)
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
