  • 2 months later...
The black is build number 98 and I too haven't seen it before.
The silver car is #8 as the plate suggests. This car has done the rounds in our discussions before. Originally in Adelaide then went to Melbourne. Low mileage car but no documentation to validate at time of sale. Did it look like a sub 40,000km car? Shame I missed it. It must have arrived late.
The red one next to it is a lovely car, previously owned by my mate, I know it well.
Cheers,
Bob.
I didn't get to see the red or silver. They came later. What time were you there I had taken my car but must have missed you there also. The black car was apparently rough and probably has had a respray and the engine bay is apparently rough as. Fourth ADM I know being restored. Seems like the value is high enough for people to start restoring them. Obviously many have been driven and enjoyed
Edited by 21PC
Hi all
Haven’t had a chance to introduce my self my name is George and I’m the new owner of the black build #98
I was hoping to catch up with a few other ADM owners over the weekend,but was at my other car most of the time blue R34 number plate WPN R34
I bought the car aprx a month ago and it has all books receipts etc with it
I was told the car sat for aprx 5 years and wasn’t driven much at all, yes in the bay they have replaced the factory intercooler and radiator with after market items.
I have all the factory items and the car will be going in for all resto work in aprx a weeks time.
I will have a load of questions regarding the work loll
Would be good to catch up with someone for advice and help.
Cheers.
  • Like 1
In my opinion it's a great car and a good purchase George. Welcome btw. I'm hearing this as second hand info and from my quick lookover at the festval I think it's a neat car you can actually drive. Controversial opinion on an ADM I actually don't mind the rims also ?. Got more details e.g interstate purchase, KMs etc?
#28 ADM GTR owner (my dad) is contemplating selling his car. He has had it stolen/badged to many times. Recently an attempt to steal it was the final straw. He has had an offer. Has lived under a cover most of its life. Has a few dents here and there drivers seat as wear in usual place. Has original front bar, and exhaust system which were swapped at Nissan for N1 and Nismo 3in. Loads more. Any interest or prices he should be looking fortapatalk_1527634978341.jpeg20170721_190003.jpeg20170722_092611.jpeg
Photos this weekend. Mileage around 53,000km. Has original books and radio also. Was purchased from Col Crawsfords. Has a warranty replaced VSpec engine fitted by Rockdale Nissan due to loss of compression in rear 2 cylinders that was changed around 25,000km mark
Is your dads car parked on the street in the St George area (I wont mention the suburb here hehe)? I'm a local to this area and I did see one parked on the street about 8mths ago or so and I thought to myself "there is no way I'd leave mine on the street like that" :)
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
