I wonder how one of these 3071's would go on an RB20? Could it be a viable option or is just going to be lag city?
The 20 is a good motor, its not the lag house everyone talks it down to be IMHO. Yet I would probably think the 3071 will not suit it, being the GT30 turbine it will need some gasflow to bring up shaft speeds for good boost response.
Probably try a 2871 for a happier street turbo on the RB20 :rofl: or a TD05/06, it all depends on desired results.
anyone no if garrett will be releasing these for the 2860-5?? im looking at buying a set for my gtr but if they goin to release a better version within the next few months ill just wait.
Oh also yeah as Deano and Ash said, im in the same boat waiting to see if they come out or not.
Prices for normal 5's will be interesting if an X wheel comes out...
yea thats the only reason i havnt really started hunting for -5. of the GTX wheels come out, the normal -5 will be worth nothing, and thats prob a good reason why garrett wont release them....
lol jezza im keen to see it
That's true, there heaps of places to get the norm -5s and i havnt brought a pair, but if the gtx version came out tomorrow I'd go buy a pair straight away. So your right there ash
No official statement... however they are not on the cards for GT28 frame at present in terms of imminent release.
Apparently it took 12-18 months for them to go from GTX4X down to the GTX3X frame.
So perhaps 12 months again.
IMO they will see heaps of sales in the GTX3X frame, so it might spur some more/new product.
Wait and see i guess.
ill keep asking some other people, see what happens.
Ggrrrrraaaaahhhhhhhhhhhhh... :)
I want more response damnit. gtx2871r + e85 would be my setup IF the gtx28 ever comes out.. perfect opportunity to swap to e85 with a new turbo ;)
My gut feeling - they will. They did the GTX4X last year, and now the 3X frame
It'll just take a while to filter. Cant mass release a heaps of products @ once due to manufacturing and also the illusion of "progression" over 3-6 years when you had the design 18months in ;)
Yea, I was about to start saving for a new car as i'm a bit over the turbo lag on my R33 GTS-T with KKR 560 and wouldn't mind a newer car.... However, GTX3071 could be enough to change all that :thumbsup:
If i've already got injectors/front mount/z32/fuel pump/power fc/locked diff, do you think theres anything else i should invest in while getting a GTX3071, like a forward facing plenum or exhaust cam gears, a new manifold or poncams or anything? Just in a value-for-money reduce lag kinda way?
EDIT: This seems to be the only GTX3071 with T3 and Internal wastegate i can find. Do I just use the stock RB25 style dump pipe or is that a different 5 bolt design? Am I crazy choosing this over spending heaps more to go external gate?
Edited by islade
gcg or mtq should both be able to get you a gtx3071 with any turbine housing you want
you cant use the standard dump, has to be custom
Edited by JonnoHR31
Value for money get the turbo with an internal gate .82 turbine housing, get an exhaust cam gear and get it retuned. You will need a line kit, intake and cooler pipping modded and a completely new dump pipe.
GCG have given me a rough price of $2200 for the GTX with rear housing. You can then get your mechanic to make you the dump/cooler/intake pipes and buy a RB/Garrett BB line kit from Kinugawa on ebay. The line kit is about $100 and I anticipate you will need to spend roughly 800 making the dump and other associated pipes. GCG also sell gates cam gears for something like $100 each and tuning will be up to your tuner.
if you really want to go the whole hog you should look to a 6boob style manifold and budget for another $2500ish.
GL
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
