That sounds like a normal GT3076 that kind of power, keen to see the dyno sheet to see how much laggier it is compared to a GT3076
They stopped intentionaly as I don't have internals. They can see this doing close to 350. No worries.
Will post the sheet when I have it.
100rwkw at 3900rpm is pretty late making power.
Do you have a plot of boost as well? It seems to be in quite late which makes me wonder if there is some improvements to be had with better boost control.
I will get that chart. Definately. I'm using a gizzmo IBC. U recon a better one will bring.power on sooner.
thats worse than my 3076r. mine makes 270@16psi on a mainline for reference internally gated
Don't look at power every dyno is different. Shape of chart is more important. So its laggier than gt3076?
.63 or .82 rear? internally gated or external?
it 'looks' a touch laggy. how does it drive?
.82
Drives very smooth. Have to admit. I wouldn't mind removing a big of lag. Just a bit. However im coming from stock turbo maybe om not that used to it. Wat things can reduce lag? Once it up and boogies it pulls like a freight train though. Lol
Really? Wasnt their goal to bring boost on earlier with the gtx?
Compare the flow maps, they flow more in the higher boost levels mainly, but also tend to be more comparable with a slightly bigger version of the same turbo. Read all of this thread, lots of pretty graphs to look at.
What made you think that?
Edited by Rolls
4800rpm for 200rwkw, ugh... Much lagging compared to a 3076
But its similar to a GTand that's pretty much where a GTX3076 sits for comparo.
unfortunately it seems Garretts GTX3x frame isn't living upto the claims
Ah ok. Have read all of the thread will be looking at getting a 3076 soon.
Dont know how I got that idea, mabey just saw the new model and presumed it would be better haha.
i would be interested to see a plot of a GT3040 (GT3082R) Vs' a GTX3076R as i think they will be pretty similar.
Personally i think that that GTX range was an attempt to gain back a bit of the market share that they were beginning to lose to other performance turbo brands like Precision and Borg Warner. They seem to have been caught napping a bit and while the others were designing completely new turbos Garrett were relying on their now old GT range and didn't seem to be working on anything new.
That is also the reason why i think that the wheels are billet as the time from design to production is a lot less with a billet part than cast, and it also means that they can easily tweek the design without the expense of re tooling.
The GTX range at the end of the day is nothing more than an updated compressor, it's not a completely new turbo just a touch up on the old design.
Edited by D_Stirls
I do remember the first releases on the GTX implied they would be at least as responsive as the GT, but I have been suspicious of that claim from the start... however this result looks too laggy. I suspect something isn't right somewhere, probably a leak of some sort more than boost control.
For what its worth, the GTX3076R would really be a GTX3077R if Garrett stuck to their normal naming conventions.
Anyone else actually got one of these? So I can compare how abnormally lsggy might e is. Ugh.
Someone previously posted on here (I think it was Ozz) on an SR20 they were virtually identical - you'd be forgiven thinking they were the same turbo on different dyno runs.
Found it on another forum - scroll down to post 37.
http://www.silviawa.com/forums/index.php?showtopic=58974&st=20
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
