The bit they had on the new Tires was interesting after a conversation i had with some Michelin big wigs last week.
When all the suppliers placed their interest Michelin pulled out when told that F1 wanted a tire that would "go off quicker" as it goes against Michelins philosophy of endurance and "economy".
There has already been some comments that the team cannot talk about the falloff due to the Pirelli being unhappy with the negative media already
Also noticed that One has Ferrari listed as "Scuderia Ferrari Malboro"
really? wow thats a bit risque!! hadnt noticed but wll look next time.
i like the idea of trashing tyres easier. makes for smoother racing. and yet the wing (which i can still see failing spectacularly) and the Kers should add the speed back into it.
Vetools time was with the wing up as much as possible and kers in use....neither of which they had last yr at this point.
woot Q1...envious of those that are there. thinking of making it our honey moon next yr. perfect timing.
Edited by boiracer
Its on the 1HD timing not the BBC one, so when they had a run down of the prac sessions pre qualifying
:unsure: Heidfeld out in 1st Qualifying session!!!
agreed. that was awesome. and lucky.
Kobayashi neeeds another drive somewhere. that was a champion effort. dam that little guy can drive!(although sauber does look alot stronger this yr already)
Edited by boiracer
Did you notice webs having a look @ the bottom of vetel's car when they were parking up after the last qualy?
koby was dammed impressive and it seems like someone lit a fire under sutil finally, dammed hot drive and one hell of a save, was thinking I'm about to watch sutil's death when he spun. sauber look hot this season.
torro in q3, holy shit.
what about massa baby, shit we area about to get eliminated, here's pull 2-4 seconds out of your ass with like 3/4 the lap done. that shit was insane.
vetel's time better than pole last season, Hol-ly f***.
Two things just happenend:
1. Either vettel is a finger wagging genius, or webber is jut as utterly useless as i thought
2. Vettel is going to go back to back. He may not even break a sweat to do it
And mclaren and ferrari are the wrong way around? where the hell did that come from louie!?! Nando will be dissappointed losing out by 1.4secs from pole.
So the bulls werent using kers, and apparently they arent saying why. Leading one to believe theres a potential issue
If for whatever reason they dont have this sorted by tomorrow, expect lewis and jense to absolutely mob them from the line
which would be a shame for vettel after that great performance
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
