Pirelli can build a good race tyre. Unfortunately they were told by the FIA to build a shit race tyre, which is what they have done. So that, combined with the DRS & KERS gives people something to bang on about. Which atleast serves to hide the fact that the integrity, soul and general whole purpose of F1 has been destroyed in the name of getting people with generally NFI to watch a race.
They can basically take their crap tyres, their fake overtaking, their hopelessly compromised energy recovery systems & all the other junk & shove it.*
Amen.
feel sory for webber he'd probably dominate if it wasnt for vettel
So far he's finished 5th, 4th, 3rd, 2nd, and 4th. My maths isn't great, but take one guy out of that mix and I still don't see him dominating...
yeh but consistent finishes like that throughout the season would 'usually' be good enough to secure a championship no? perhaps with a couple of 1sts in the mix. Dont the first 8 score points in lowering order from 1st back?
also isnt there a lot of talk that vettel gets priorety treatments/car parts etc?
lots of talk yes, but I dont think it has been substansiated yet
Remove Vettel entirely and it would be:
Ham 96
Web 85
But 78
Alo 63
That might look like Mark dominating to some of his one-eyed fans
And that doesn't factor in whoever would be driving the other Red Bull car if Vettel wasn't, or what Vettel's results would be in a different car... With Some of Mark's results, just about any other decent F1 driver in a Red Bull would have beaten him a few times this year.
other than the wing last year, that was a dubvious performance adbvantage at best, there's no credible reports of less favourable treatment or parts for Webber.
Edited by hrd-hr30
Points system has changed Alex...Top 10 score now
1st - 25
2nd - 18
3rd - 15
4th - 12
5th - 10
6th - 8
7th - 6
8th - 4
9th - 2
10th - 1
Rewards winners more than it used to in order to stop people being so willing to 'settle' for 2nd place etc..
Webber had his chance to win a WDC and he fucked it. He'll never be a WDC now, short of Vettel/Hamilton not racing anymore this year
I was only saying the other day that I think I actually like Hamilton now... then i go and read this ... http://www.planetf1.com/driver/18227/6950922/Hamilton-hopes-to-close-the-gap
Right now he is back to his c0ck gargling ways of yesteryear...come on Button smach the little poser!
http://www.jamesallenonf1.com/2011/05/tight-monaco-grand-prix-in-prospect-strategists-say/
"The super soft Pirelli tyre, which makes its debut this weekend, is expected to last around 8 laps in the opening stint"
are they serious? 8 laps!
might be worth a wager on the first of the driver's who start on primes.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
