Dont bother, just watch the highlights package
Watching the Alonso spin is worth a few views for the lulz. Between him and Louie they just dont know when to say when
I'd hardly put Alonso in the same category as Hamilton. Looked like a pure racing incident to me. Button had the inside line but that is the outside line being a chicane.
He didnt really have anywhere to go short of almost stopping mid corner imo, and the stewards seem to agree
Watching the Alonso being punted off is worth a few views for the lulz. Between him and Louie they just dont know when to say when
fixed that for ya. it wasn't a 'spin'. He left room for Button. Button didn't return the favour and decided to use the 2011 McLaren tactic of "if you can't pass them, punt them" and barged into his rear tyre. Good thing they engineer the McLaren front A arms to be Lewis proof...
Edited by hrd-hr30
Schumacher had Webber lined up at turn 1 on one of the restarts but didn't punt him. Lucky there wasn't a WDC resting on it.
Very un-Schumacher-esque.
It was great to see Schuey actually looking like he should be there rather than looking like Rosberg's lapdog.
No he didnt. Button was there, alonso refused to yield
He was up the inside and alonso decided to turn in and bump wheels, unfortunately for nando, he came off second best.
Full crdit to schumacher for this, which is rare for me, but if it was button v schui, i dont think the cars would have touched.
I call that leaving room (which is yeilding - he certainly did not turn in on him) and being punted in the rear tyre.
Edited by hrd-hr30
a) Thankful I woke up after my alarm at 4 instead of 2 (although I did miss the Louis show :/ )
b) F1 + cotton wool = Montreal?
c) Awesome drive by Button
d) Definitely robbed of a great battle between Schumi and Webber, for a podium, on a tricky circuit, in tricky conditions by the poorly devised DRS.
good drive from webber today. And great to see vettel throw it away
:O and :D
I call it as alonso braking far too late into a corner in a vien attemp to hold a position that he had already lost
That picture is deceiving, Fernando has gone far too deep into the corner. The replay from the mercedes rear wing shows how late he had to brake to make the corner as well as the steering angle he cranked on to make it stick.
much like louie, to stubborn to admit defeat
Alonso braked very late yes, but made the corner no problem at all, while leaving room for the other car AND putting all but a car-length on him in the process! It's Button who didn't slow enough and couldn't make the corner without running into the other car. quite often the racing line is more slippery in the wet and that probably contributed to Jenson understeering into him. I don't think he hit him intentionally, those smart arse remarks were more putting shit on Louise.
I think the drivers need to man up and race in the rain. They are the best in the world (and paid that way too), i'm pretty sure the throttle goes both ways, if you're too scared (that's you vetool) you can always pull into the pits and retire.
The dumb thing is that the track get worse when the cars arn't circulating at speed
Edited by sav man
My take on the Alonso vs Button thing is it was a racing inceident with Button most at fault. Alonso was clever with hanging around the outside knowing that if he left Button enough room on the inside that he would not be able to get far enough alongside before the left hander and he would have been able to slow them both up at the apex to the left hander and Button would have not got past.
But in being clever and trying to apply some race craft he left himself exposed to being punted. I think the fact that Button is a clean racer he thought it was a minimal risk, however in teh slick conditions that car just got away from him and he punted Alonso. Would have been great racing if Button had of managed to just slow the car up a tad more.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
