I've been saying that since the mid 90's and here we are lol.....
my new formula would be:
3.0 Litre DOHC 5 valve per cylinder max twin turbo V10.
Or upto 8 Litre naturally aspirated, any configuration.
Free aero, apart from front and rear wing wake and air disturbance massively reduced.
Full ground effects floor, tunnel and diffuser allowed.
No kers or any other device of this nature.
alcohol based fuel.
minimum two tyre manufacturers.
cockpit equalised so that no driver is held back by weight or size.
Larger tyres, much different profiles, probably 18"
If full ground effects were allowed back (sliding skirts, tunnes... etc) the cars would have tiny wings anyway, regardless of rules.
I think the old 1.5 turbo or 3.5 na is the way to go, but leave the piston count and layout free. The turbo tech that would come out of low capasity engines would be great
by the looks of the rule changes...i dont think i'll be watching after 2013 anyways. so they can all do what they like
good point. I figure if I up my alchol consumption by about 30% I will soon forget all the WDC results from 1985 to 2000 and I can then just re-warch those 15 years of F1 over and over again...
yeah agreed. 3l turbo and 8L na is waaay too big. get them to make a max 1.5L turbo or 3L na as the maximums. they can easily get 800hp-1000hp from either 1.5L turbo or a 3L v10 NA so then they get to chose reliability (800hp) or power (1000hp). or spend more and have both!
if really generous up it to 2L turbo and 3.5L NA. that is plenty.
I like the idea of cockpit rules though and perhaps raise min weights so that fat drviers aren't penalised! lol. i'm sure there's some talented fatties out there... would surely help webber to be on an even keel weight wise with vettel. he is giving away probably half a tenth per lap in body weight penalty alone.
....actually the way Raikonnen is going on the tooth he might need an extra widebody F1 car if he makes a come back.
I wonder what mods they made to get Tony Stewart in the MP4-23 did they graft the A to B pillars from a BA Falcon with a seat located in the middle to fit him in? It would have left room for space to sit a pizza, a couple of burgers and cupholders for a big gulp.
I would love to see more taller/bigger drivers have a shot at F1 but realistically it is a sport for rich midgets.
alcohol based fuel.
then i'd def be watching. :)
sadly.....very unlikely
I'd be happy to keep the current capacity, what is it 2.4L? They can make plenty of power from that capacity these days. But allow whatever configuration they want to run as far as how many cylinders etc, and have no rev limit.
It could give some more variety in the field, the way its going it will be a common pretty much everything ala V8 Supertaxi's in a few years.
No rev limit could potentially reward teams willing to push the limits of engine reliability if they can hold them together. I don't see the problem with that because they already get penalised for using too many engines anyway, so why not let them push the envelope of reliability?
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
