lol, yeah look like benneton had the blown rear diffuser back in ye olde times but I wonder if they had the ECU smarts that could make the engine produce 80% of it's peak exhaust gas even when at part throttle? that's the key as far as I know to making them really useful.
I should explain. those pics were robbed from when the car was for sale about a year ago. engine had a recent rebuild by a engineering firm of the name maclaren. not sure of it's affiliation, if any, with Bruce's mob of the same name. probably not related at all.
steve-o. these pics were taken in the last year or so but that would be how the cars were (are?) timed. don't forget this thing ran in 1988 but even still timing of cars with transmitters has not really advanced at all in that time. the tech is pretty robust and useful as it is.
lol baron i think the engine would have been the limiting factor for benetton, given what we know about their masterful engine mode mapping in the mid 90's ..... haha
And yeah, exhaust blowing techniques have been around for quite a while, its probably just now they have pulled it out of the old tech recycle bin.
Blown diffusers have been around for ages. But off throttle blown diffusers are a relatively new innovation.
According to the website it was once related, but not anymore.
Did anyone else notice there were no retirements from the Gp on the weekend. AFAIK that has never happened.
It has happened before, but it's pretty rare. It happened a few years ago, like 05 or 06... or maybe 07?
I went & looked it up. Sort of
The answer is supposedly two.
Two are Monza in 2005.
The Dutch GP in 1961.
The big news is:
Narain Karthikeyan is the first driver in F1 history to finish 24th.
FIA confirms 1.6 turbo engines for 2014
The FIA, motorsport’s governing body, has confirmed that Formula One racing will move to new engine regulations in 2014, with the current 2.4 litre V8s being replaced by more efficient 1.6 litre, turbocharged V6s.
The FIA had originally planned a switch to four-cylinder engines in 2013, but has approved the revised formula in light of concerns formalised last week by various interested parties.
“Following a fax vote by its members, the World Motor Sport Council has ratified the engine regulations recently drawn up in consultation with the main stakeholders in Formula One,” read an FIA statement.
“The new power plant will be a V6 1.6 turbo unit with energy recovery systems. This new formula will come into effect as from the start of the 2014 FIA Formula One World Championship season.”
The new energy recovery systems (ERS) will replace the current kinetic energy recovery systems (KERS) and are expected to be more powerful. Combined with the legalisation of turbocharging, they will ensure overall power outputs remain similar to current levels, despite an anticipated drop in the permitted rev limit.
Formula One’s last turbo era ended in 1988, a season dominated by the 1.5 litre V6 Honda-powered McLaren’s of Alain Prost and Ayrton Senna. The sport returned to naturally aspirated engines in 1989, with a new 3.5 litre formula
Was looking at old Jordan pics, their exhaust blew into the underside of the rear diffuser in the 90s
Yeah right you're looking at blowing the 'other Jordan' pics Mr Brisby, we're onto you ;)
Sooo, 26 years later, we're going back to 100ml larger V6's, with a reduced rev limit and better materials, what a technological break-through this will be ...
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
