booooooooooooooooooooooooooooooooooo robbed from a decent quali AGAIN
But murray back in the box!!
Anyway, my fear has been confirmed, the EBD was the major piece development keeping mclaren close to redbull. Now that its gone, that traditional wayward rear end is back and now they're fcuked
WCC is now over too. shame
This situation with the blown diffuser rules is becoming a farce. The rules should not change within a race weekend. Hell, they should be locked in for a full year, safety aside. Different rules for different teams, changing rules between practice sessions ... the FIA should quit trying to fix the races.
One are hopeless. Cutting to ads when showing Webber's in car lap
THIS.
Couldn't agree any more. Plus half the time they have p.o.s "technical difficulties". Probably some fat bastard behind the scenes pulled a cord out while playing WOW.
Aussie starting first, Aussie starting last, we've got em surrounded! haha
What happened with Ricciardo? I didn't get to catch qualy... was that as good as he could get or was he caught out by the rain at the end?
Got bad deal with second half of qually as it started to rain and he was in the pits a lot of them got caught out
Let's see what happens during the race before making any comments about his creds remember it's his firt time in this car
Edited by stR33ter
just imagine if the BBC TV director was Australian; Today he could swap between footage of Ricciardo possibly making up places and Webber gradually slipping down the field :)
And button and Lewis burning up sets of rears again??
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
