Anyway todays question should be who should MB sign to replace Schumacher. Preferably someone who can keep up with Rosberg.
As was previously suggested, di Resta would be good. Or maybe Heidfeld since he's been screwed over by Renno.
Depends if Schumacher keeps having good races like he is. I get the feeling that if Nico fails to properly get the upper hand on Schumacher from now on it may seriously damage his career going forward.
Webber's big year is the next one, he's had this year to come to grips with the new tyres against a Vettel in top form, so it's crunch time as of Australia 2012.
Jense is really delivering for McLaren, definitely a likable guy, unlike that other dickhead they employ.
I hope the Yukuza cut Vettel's fingers off.
That is all.
apparently this is the full transcript of the schumi v Hamilton blocking incident.
pf1
Engineer: Michael, we're concerned you might get a penalty for blocking.Michael: Why?
Emgneer: Because Race Control just warned us you were blocking.
Micaehl: Blocking? Why - it's my own team-mate?
Engineer: No, it's Hamilton. That yellow helmet is Hamilton not Nico.
Michael: Oh (pause) I can't see anything in my mirrors.
Engineer: Are the mirrors broken?
Michael: No, somebody has stuck a nice photo of Kobayashi in the left mirror and Petrov in the right mirror.
Engineer: Can you repeat that?
Michael: Only joking - hang on a second, we're coming up to Ascari ...Yes! And again he fails to take The Schum! Get in there mein Sohn!
Engineer: Michael, you have to stop blocking.
Michael: We are having a nice battle.
Engineer: Charlie doesn't see it that way.
Michael: You know I wonder if I can get him onto the grass this lap...
Engineer: If you don't stop blocking I'm going to get Ross.
Michael: Not listening!
Ross: Michael, this is Ross. You have to leave room for Lewis at Ascari
Michael: There is plenty of room.
Ross: You need to leave a car's width of tarmac, not just a car's width between yours and the barrier.
Michael: This really is a nice lot of fun.
Ross: Michael, you have to leave Lewis room, if you collide-
Michael: He'll get the blame. He always gets the blame for everything. It won't be a problem.
Ross: We had enough trouble with Rubens last year.
Michael: Schum, Schum, Schum Schum, Schuuuuuuuuuum!
Ross: If you don't move over I'll tell people about 1994.
Michael: Er...you know, I think my tyres are going off.
[Ends]
i found that entertaining, so much so i dont believe a german said it......
pf1
[Ends]
It's the only part of PF1 worth reading that segment, god the forum is f**king retarded.
I've said it before and I'll say it again, rev limiting the cars ruins the overtaking a bit.
The whole "Do we dare turn the revs up for a lap to make a pass, knowing that it may result in the dreaded white and blue smoke?" was exciting.
Engine freeze is shit, atleast the engines have the slightest relevance to road cars, unlike hypersensitive aerodynamics.....
So one good race in two seasons of mediocrity & suddenly the pressure is on the other guy?
Sorry mate but it looks for all the world like Webbers big year was last year. Maybe it is the new tyre but he is struggling massively this year.
Bit of a harsh call on Sam Micheal?
Do you, like, know people? :whistling:
i've not been on the pf1 forum, i just look at the highlights and the pics. :)
so we gonna make some t shirts?
i think the only problem is you need to order somethink like 50 shirts before they will make them.
Edited by tweety bird
yeah as much as I love schuey he's hardly putting the sword into nico just yet. he's started to come on strong lately but nico has certainly had the upper hand till now.
Look through Hamo glasses when he turns his head and I wonder whether he has been crying. He seems to be wiping the sides of his eyes...and their appears to be a reflection at the bottom of his eyes behind his glasses. Probaby perspiration...but wouldnt surprise me
i like the fact that webber, unlike most drivers, will admit when he's cocked up in most cases. there's some drivers out there who could run off the road with no-one around them and they'd try and blame oil put down by a car in a race 3 years ago before they'd take responsibility for the fact that they out braked themselves, or ran wide, etc.
that's a very Australian trait that I like a lot... Europeans and Yanks are never wrong even when they clearly are... just makes you look like a fool I reckon... if you own up straight away then there's not much more to be said and you sometimes disarm the interviewer who's really out to have a bit of a fight and record some controversy
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
