when they cut to the shot of him talking to Horner on the pitwall straight after, I was sure he was about to start bawling.
cheer up emo kid, it's not like a DNF makes a difference to the championship for anyone
RBR making Webber look woeful. He had 3rd and a good chance at 2nd had they not stuffed his pitstop. After the delay in the stop he was quicker in the second stint. Button had a problem with KERS but Webber was quicker then everyone inc Hamo. If he didnt get dicked with track position he may have been able to use that pace, would have been a shoe in for 3rd and a possible second.
Admit that he was never going to win after the first two laps though, he needs to defend more like the Webber of old, rather than the 2011 Webebr where he things he will be patient and use car speed to get them back in a later phase
I disagree...Considering he was on the option while the rest of the front runners were on the prime, it made him look better...When they were all on the same tire, Massa had him covered....
Don't forget he's in the undisputed best car on the grid, and is regularly finishing behind Hamilton/Button/Alonso
Don't agree. Webber had a stop that cost him about 9 seconds, he came out about 8 seconds behind Massa and in 5-6 laps was on his and Buttons bum. In that period he was the quickest guy on the track. Webber was all over the backs of Massa and Button, just didnt have the straight line to get it done without being waaay aggressive.
Last stint, yes he was on the quicker tyre, but all mid stint he was on the same tyre and was quicker...just couldnt cleanly get by Massa and Button. Even in the first stint he seemed to be quicker but had to just sit back and preserve the tyre and fuel because Button had him covered as Webebr could only do the job in the first DRS zone and the McLaren had such a straight line advantage that he could sail by in the second, shorter DRS zone
Stop cost him 6 seconds really (9ish second stop from memory, good pitstop is about 3.4s)
I'm a fan of Webber, I really want him to win. But I'm afriad he's just not doing the job at the moment. Wether that is 100% his fault or not, I cant say (maybe the car is designed more for Vettel's style, these are the things we will never know)
Not really sure why He wasn't trying to outbrake Button at the end of the DRS zones but, Thought he would have tried to attack a bit more.
Hopefully the rumours about Kimi Raikkonen coming back to F1 turn out. I'm not sure how competitve he will be in a Willams but still be good to see him racing again, especially if he drives it like he did the MP4-20
It seems pretty clear that the RB does suit Vettel simply because he can pull away in the first few laps whereas Mark is a slow starter and then gets nowhere in traffic due to the RB's poor straight line speed and dirty air grip. The Mac for one is faster, the main reason they don't win more often is because they don't have Vettel who is clearly the best driver around.
button is good under brakes though. i think webber knew that if it came to a battle of the late brakers then button would win. no point binning a car trying to make the pass. he isn't massa or hamo.......
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
