  • Replies 131
Results are all entered, we are just sorting the new spreadsheet. Leon should hopefully post them up tommorow evening.
Deca Refunds: Need bank details from the following:
Ryan Loos
Kieran Robinson
Vince Ritchie
Ok...at the risk of getting my post changed into something to amuse the community...where are the results? it used to be out in 3-4 days tops...its been over 8 days now? whats going on?
Testing, obviously is not going as well as planned.
Sandeep has been kind enough to spend many hours reformulating the spreadsheet for results so its easier/faster and allows for automation down the track.
So the guys are not doubt checking 100% that all the forumla/calculations work correctly. This basically means doing the results twice.
Makes sense to do it all at the same time, makes easy work rather than "doing it later" which means it never gets done :P
I don't think 8 days is much of a pain to be honest.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
