  • Replies 174
Posted Images
Good to see this kit available at last! Have to say 450kw is somewhat underwhelming but the extra capacity will have to translate to more power. It will be great to see someone build either a drag or a circuit car and see what it is really able to do!
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5559244
please note this is on pump fuel with a rb25 head
another note is that the builder needed to get a new clutch because of the extra torque
hope to build this in the future.
I am sure it is capable of much more. The 3L going into my Stagea is looking too small already!
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5559371
Its a sad day when 608hp/450kw doesnt impress.
That said, im sure Brad couldve got a T51RSPL on there at 2 bar on e85 if he wanted a big number, surely the point here is just crazy low end grunt more than a big hp number :)
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5560137
yeah id like to see the power curves on this engine.
he was making close to 580-590hp with the 3.0l so this is a great improvement especialy how it is relativly cheap comapeared to a full house jap bottom end.
probly total cost for the whole engine is 6k - 10k by guesstimation.
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5562467
There is a price at the top of $5500 for the rolling assembly so you would have to say closer to 10k all up ready to go depending on how far you go.
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5562573
RB34DET Results
RB34DET 'vs' RB30DET
The RB30DET boost and power curve is in green and the RB34DET is in red
A comparison between the old RB30DET engine and the new RB34DET stroker engine is complete. The two engines are identical in every way except for the new stroker crank set up. The purpose of building two near identical engines was the only real way to make a true comparison between a RB30/25 and a RB34/25.
We arent trying to make the most power or we wouldnt be using pump fuel and a medium frame old school T04Z, we are trying to make a comparison.
Straight from the horses mouth.
https://www.sau.com.au/forums/topic/344999-rb34-on-sale/#findComment-5563198
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
