last day of rego for the r33 before it got its new suspension tyres / radiator / stock intake.
should be back on the road in january. - new rego!
then z32 afm , power fc goes on / tune / dyno - hoping for a 250kw tune
Link removed by Moderators, PM sent.
i can now vouch for their toughness.
clutch required a bleed after that episode.
Edited by GoldZilla
https://www.sau.com.au/forums/topic/345801-skyrice/
  • Replies 48
Hey Keir, you probably won't get a really positive response to that in this section of the forum.
Personally, I don't think its some of your best work, we all get grief at some point driving imports, because of the "guilt by association" reputation they have. This is EXACTLY how it happens. I like a burnout as much as the next guy, but faark, in the street? Youtube? How original. Great piece of footage for Today Tonight's next "Import Driving Hoons" story.
I'll be honest with you, if you did that in my street; I'd tell you to piss off and take it to a track. If I saw you do it again, I'd be giving your rego to the police.
We all have a responsibility to think a little bit about this kind of thing, otherwise, the cars, and the lifestyle we love will be taken away by simpering, sooky, politicians looking for an easy vote. Then you'll be driving a bloody Camry wondering how it all went so wrong.
That said, hope the rebuild goes well, looking forward to seeing some pics of it ON A TRACK!
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5569969
this was in the back quarter of an industrial area in the middle of the night in a dead end street. he spent 30 minutes trying to find the most out of the way place on location on a return test drive.. my mate couldnt help himself.
daleo - fair call i cant understand where your coming from. - it was reckless..
i actually wasnt driving. :whistling:
was the first night we got it boosting right.. and my mate decided he was keen to see if it could finally boost a burnout.
its actually from weeks ago i wasnt going to post it but thought it was amusing. :)
i shouldve gone with my first hunch and not posted this.. heh
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571727
This took on a bit of a life of its own eh?
I'm the first to admit to some monumentally stupid car behaviour in the past, some of the other posts give the impression they've never done a skid.
You won't get any more criticism from me.
Get going on that rebuild.
Cheers, Dale
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571761
Cheers, Dale
life of its own it did.. guess i shouldve put a bit more thought into posting that video.
didnt feel criticised dale, more enlightened to your mature perspective.
cheers. keir.
Edited by PetroDola
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571797
The fact that this is "in the back quarter of an industrial area in the middle of the night in a dead end street" is no excuse - it's still on the street and as has been said, it's videos and posts like these that bring a bad name to the whole car community, especially Skylines.
https://www.sau.com.au/forums/topic/345801-skyrice/#findComment-5571870
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
