And a HUGE thanks to all volunteers, from BBQ to merchandise to sign on (Tegan did great after Anna and Duncan had to stop), cones to timing to sceuitineering - the list could go on and on!
Thanks everyone, without your help these days can't happen
yeah I enjoyed once I figured out (last 2 runs) why the hell the car wasn't making any power at all ie. TCS was ON *facepalm* This is what happens when you drive a skyline with 2 hours of sleep night before..
On the first run I rode my clutch like crazy and smoke started coming out of it like mad ... I let it cool down but can still smell that stench. Doesn't seem to be slipping though. What's the chances it's gonna have permanent damage ? I rode that thing like a mofo trying to "wing it" on the first course..
it was a good day and im suprised the rain held out as long as it did. Huge thanks to the guy with the white 180, without his fathers help i dont think i would have got the battery secured and got out on the track.
Looking forward to pics and results.
so un new mx5 not so great as last one :) SO BOATY!!!!
time for new tyres and sway bars me thinks!!!! handles like shit (for an mx5... still beat some of you tho :))
thanks again to everyone that helped out..
i'd like to thank Doof, Mitch Moo, Spanna, Eric, Shell, Dave, Matt, Ben M, Mark, Steve-O, Reece, Tegan, Ben Sinclair, and anyone else who i may have forgotten (sorry) for all their help today in the timing, photos and just standing in the horrid rain to make this day possible.
I'd also liek to thank a few of the girlfriends who helped out.... sorry i dont your names, but it was very nice of you to help at sign on and with lunch :)
if i have forgotten to thank anyone please kick my arse about it :D
WOOO!!! BRING ON NEXT TEXI!!!
It was good to catch up with those I know and meeting those who you I didn't know before today. There were some pretty epic skids out there today! Nicely done people. I think the rain added a lil something extra in the afternoon too :)
Literally hundreds of more shots on the disc. PM Me or Talk to Pezhead if you haven't ordered one yet.
Love how straight this GTR is.
zoom zoom.
Red Rocket.
Battle of the boats.
Bed time now. Enjoy!
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
