Hey guys, as the title says, my battery is going dead flat within as little as 1 day. The battery is 4 weeks old. Using a multimeter between the -nve on the battery and the battery lead, its showing 0.42A. I removed every fuse inside 1 by 1 as my step dad watched the screen, it didnt change. When I got to the fuses in the engine bay, when I remove IGN SWITCH it drops down to 0.03A. So its safe to say its something that runs off of there, the question is, what does run off of there? I noticed removing the fuse and placing it back in, that one of the relays behind the ECU is clicking when doing so. I should note that this car has a RB25DET conversion, so wiring is far from untouched...
Any help would be greatly appreciated...
-Dion.
EDIT: Key was OFF while this was tested.
https://www.sau.com.au/forums/topic/347437-r32-battery-going-flat/
If your near parafield airport I can have a look for you. Has this happened before since the conversion. Or has it only just started. You must have something wired up continuous instead of being on the acc or ign citcuit. Im on holidays so im free most days if your coming past.
You might be measuring the amps incorrectly. The ammeter needs to be in series, so you disconnect the +ve terminal and connect the ammeter between the +ve of the battery and the +ve terminal/cable. 0.42A shouldn't be enough drain on the battery to flatten it in a day.
Also, when the engine is running, how many volts at the battery? How many volts at 2k rpm?
Fitted any new electronics lately? Alarm? GPS tracker? Neons? LEDs?
None of the above, but I am treating the alarm as a suspect, because it, well, sounds a bit sick on battery backup.
Cheers for the offer mate, I'll do a bit more scrounging tomorrow and see what I come up with and yeah I'll flick you a PM, I live out of Gawler. Its been happening since the engine conversion, it seems like its getting worse, but it might be my imagination as uni has finished so Im looking at the car alot more.
I'll try that tomorrow and let you know what it says. pretty sure it was reading 13.6-8 volts on idle at the terminals, and it would drop about 0.3V when you put the lights on. I will confirm tomorrow and also check what its doing at 2000rpm.
Thanks guys! :)
Just reflecting, the car sat for months and months with no engine, if the battery backup for the alarm kicked the bucket from being dead flat for so long, could that zap voltage?
Havent got out there again yet, was too hot yesterday. Somebody suggested the fuel pump relay might be faulty as that is located behind the ECU where that click is coming from, so I guess I'll check that out too. I wish I could disconnect my alarm to see if that stops it, but I dont know how, lol.
Every morning my car feels low on juice. I hate these dogshit alarms that most skylines come imported with. With my old skyline, soooo many times at night you hear a faint siren and you can just hear the alarm going off ever so quietly under the bonnet.
When measuring current draw, what setting do you put the multimeter on?
Edited by SargeRX8
Its on 10A. Know all too well the faint siren thing haha. When I got home from work just before I turned off the siren with the key and pulled out the IGN SW fuse so I could get a good nights sleep :P My car is in a locked garage behind a perimeter fence with dogs roaming, should be safe.
unlikely but try unplugging the alternator when testing current draw
Good idea. Will try this tomorrow.
Okay, done some more playing around, so I have some new info. With the IGN SW fuse missing, the car sat for 3 days, with the alarm active, and when I went out there to start it (after the fuse was back in of course) it started without any hesitation at all. So that backs up what the multimeter was telling me. I have some pictures, since they tell 1000 words.
Everything switched off, all fuses in.
Everything switched off, IGN SW fuse removed.
Everything switched off, IGN SW fuse back in, but the blue relay in the picture below disconnected.
I understand that relay to be for the EFI, but the car seems perfectly fine without it connected (I road tested it also).
Voltage at the terminals, 850rpm, everything off.
Voltage at the terminals, 850rpm, headlights on.
Voltage at the terminals, 2000rpm, everything off.
So I guess the question is, do I simply leave the blue relay unplugged? Nothing seems to have changed with it unplugged (all accessories work, and drives fine) except for the fact the current draw is now at an acceptable level.
Thoughts anyone?
It sounds like your fuel pump is connected all the time can you check to see if there is 12v at the pump when car is off. The relay should turn the pump on and off with the ignition. Also check to see if the 12v goes at the pump when you pull the fuse just for me to think about it
When the car is off voltage at the pump is 0. When the ignition is either on, or the car idling, Ive gotten all sorts of voltages out of it (5V-12V - 13V if I use the chassis as earth instead of the earth wire and car is running), but one thing remains consistant, key off - no voltage, key on - voltage. Removing the IGN SW fuse cuts the pump, but removing the blue relay does nothing to the voltage at all.
EDIT: If I remove the other blue relay as well, car will not start. Fuel pump still goes but there is no ignition - so that one is obviously for the ECU.
I looked at a few schematics and there is an ignition relay on that circuit for the coilpacks. That blue relay could be for that. Saying that I would be taking the multimeter and checking most of your sensors. Start with a coilpack and see if there is a 12v supply on pins 2 & 3. Last 2 left to right looking at the plug dissconected. Also check AFM and oxy sensor, CAS, TPS all of these sensors are off the ignition circuit. They all shouldnt have 12v supply until the ign is on.
Ok. The following sequence of photos is related only to the removal and replacement of the relay pictured below, no other fuses or relays were touched.
Tested 4 things, Coilpacks, CAS, TPS, OXY SENSOR. - Relay was IN
Coilpacks and TPS function correctly - voltage when IGN ON, no voltage when IGN OFF.
CAS and OXY SENSOR did return voltage when off, details below.
CAS:
IGN OFF, Relay IN
IGN OFF, Relay OUT
IGN ON, Relay IN
IGN ON, Relay OUT
OXY SENSOR: - This was done on 1 of the 3 wires, but they all read the same +/-0.01V
IGN OFF, Relay IN
IGN OFF, Relay OUT
IGN ON, Relay IN
IGN ON, Relay OUT
Weird Much? :mellow::blink:
The first picture with the relay removed shows a lot of tape above it has the relay been choped and wired in. It sounds like the ign and relay are in parallel. Which means there are 2 circuits feeding the CAS. The 5.0V should only be there when ign is on. Does the relay click when you plug it in or out. It starting to sound like that relay is wired wrong. Also looking at the r32 rb20det schematic it dosent show any relays for the CAS and oxy sensor where the R33 rb25det shows a relay that turns these on and off through the ign switch. Id take it back to where it was wired. You wouldnt of noticed the battery going flat until now because if it was healthy it would of drained down slowly. PM me if you still cant get it Im home tommorrow(Tuesday).
Yeah it does click when you plug/unplug it. Regardless of IGN position. I'll flick you a PM aswell.
i had identicle problem in r33 gtst
it was the alternator. is shit a diode so there was a small current draw all the time.
same thing happened to a mates 32gtr and it was same problem there.
unplug all the leads on alternator and leave car for a few days,
quick check
hop in the boot and get someone to shut it (and let you out obviously)
the light will probably stay on
pull the globe out
(p.s. i didn't read your whole thread so i'm not sure what you have tried or not)
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
