Harry I see your point.
Classes mean little to me as well, as my 210rwkw could (will) be up against 250rwkw+ Emo's, S and R chassis etc in club sprint.
But who cares, its a fugg'n great track and a great event.
Comm'on make the trip.
I'm in 100% with my new setup and again in open class. Gotta keep an eye out for when entries are up.
Clubsprint class will again be dominated by R35's and Evos but who cares.
I wanna go 5 secs faster this year and get a 1min 42 with my new setup. :) Will be a challenge.
BTW Marlin. We need to organise a team 32 garage with you, me, Adz and Troy if he's man enough...
What's wrong with 5 point Troy?
I'd forgotten all about this,,,.I subscibed to the newsletter today,,,so looks like the gts-t has a dead line now. Thanks Troy for starting the thread or I would have not known.
Cheers
Neil.
Hsve you ever used one? My balls get in the way! :(
My nuts are way bigger than yours, and I have no problem.
At least with a 5 point it's much easier to keep the side straps down over your thighs where they're meant to be, and not trying to ride up over your guts.
troy has massive nards. that's the problem.
good to see some new blood keen to have a go. you are bound to have fun no matter what and you get to be there with the big boys. :)
im planing to run in my gts4
and the road tyers are wrong for any thing uther than a one lap dash
that's exactly what this is. 1 lap dash. :) come out, warm it up and go for it. :)
i thort is was like a 10min/15min time fram to post you best lap time
not 3/4 track worm up and go for it for one lap then back in
as i didnt make it down for the last one
18 munths no raceing next year is going to be full for me
state hillclimb and this and a super sprint or to and the sau nats
My guts hang nicely over mine keeping the straps from riding up too high
Isn't all this CAMS rules crap and tube frame cars entering kinda killing the whole idea of time attack, I thought that what got everyone excited about was seeing real cars go really fast, not cars that are too much of a race car. I was kinda hoping it was going to fill that long void we have lived with in Australia since touring cars stopped being cars, (end of group A.) Bring back Group A style cars and make the metal work of the car a limiting factor for speed. Make it a little wild then people will watch.
Keep it real like the old days of overpowered cars blasting around make it exciting, if we wanted to watch race cars we would all be on a V8 supercar website dreaming about aour new HSV GTS R8 W427 GT Super taxi's.
The Pro-cars are hardly "real cars" most of them are to serious even for Sport Sedans.
Even some of the open class cars last year would have been at home in a Sport Sedan series.
Superlap/Jap time attack events have always been "he who has the most wallet wins the day"
I would like to see the cars do 2 or 3 timed flying laps and have the lap times averaged out, that way we could seperate the grenades that chew a set of tyres and a engine in 1 lap, from those who have propper race cars.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
