Chassis
• OEM strut towers must be retained and used.
• OEM floor must be retained.
• OEM firewall must be retained. Modifications to the firewall are allowed for roll cage, engine fitment, transmission fitment and wiring. All holes must be sealed. If the firewall is provisioned for to allow clearance for a different engine or allow gearbox/drive train fitment, all material must be replaced with the same thickness sheet metal as the factory material.
• The rear most part of the engine block may be no more than 2 inches rearward of the most forward point of the firewall, If the vehicle is rear engine, the front most part of the engine block may be no more than 2 inches forward of the most rear point of the firewall.
• Chassis rails may be modified for fitment issues, all chassis rail modifications must be submitted to the promoter for approval.
• Tube frame chassis extensions are NOT permitted
Can’t see how this is close to CAMS Sports Sedan Specs, yes some of the cars running would be able to run in Sports Sedan with some aero taken off. But far from Tube frame and mid mount motors.
So let me get this right. You can now have tube frame cars, but Porsches are still not allowed?
The mind boggles.
The "No rear engine 6 Cylinder or above vehicles allowed" is only for Clubsprint.
Porsches are allowed in Open and Pro Classes.
http://www.worldtimeattack.com/index.php/cyber-evo-returns-to-defend-the-title/
“We will only be doing one event in 2011 and that is World Time Attack, we had such a fantastic experience last year”
Doesn't have to comply with CAMs spec , very few do, comply with CAMs rules and why should they - one doesnt - two don't nor do the rest - and as if they! are about to do anything about it the next decade! I think you will find most organisers are happy with FAI stamp these days
We had a great time at SL, got some tune issues to sort on the link G4 system, we will be in club sprint 2011, hopefully both cars, (R32 & R33) maybe even a VZ taxi in open
Heard a remour CAMs Actually now means Confederation of Australian Motorsports sux - what a shame!
Chassis
Can't see how this is close to CAMS Sports Sedan Specs, yes some of the cars running would be able to run in Sports Sedan with some aero taken off. But far from Tube frame and mid mount motors.
Someone wanna buy me a turbo kit so I can have a crack?
Old man is about to start advertising his 1995 Turbo MX5 to buy some new Honda motor bike. Runs a Mazda Familia GTR motor and turbo, RX7 S6 gear box, Guru LSD, Motec, Willwood brakes, Koni coil over’s. 220kw@wheels, CAMS log booked with full road rego and engineers report all for $20,000. Would be a nice upgrade for you!
Chassis
The rules you have quoted are only for the Open class. In the Pro class there is no mention of disallowing tube frames and there is no mention of having to USE the strut towers (just that you have to keep them - I wonder how much of them you need to keep?). It has no mention of having to use the OEM suspension design at all (it explicitly states this in the Open class).
There is also no mention of needing to keep the OEM floor in the Pro class. From what I can read, it looks like the only things of the original chassis you need to keep are the strut towers and the firewall. You do need to get permission to modify the chassis rails, so presumably they expect you to keep those as well? They really do need to clarify the class rules a bit better, it's open to wild interpretation.
Good to see that it looks like Porsches (and Fezzas, Lambos etc) can at least now enter the Pro and Open classes.
Good point mattah I just scanned threw Pro Class rules thinking they were the same. Glad I’m not entering the pro class.
As for tyres looks like the Advan AO50R will be the most popular pick or any one got any other ideas?
Anyone got any feedback about running the soft or medium compounds in AO50R, how soft are the soft tyres or most people using the mediums?
Good point mattah I just scanned threw Pro Class rules thinking they were the same. Glad Im not entering the pro class.
For a GTR I reckon mediums are soft enough. Unless if it's super light weight.
From memory last year the yanks were using Hankooks and panspeed were on Dunlop 03G's so it's not all Advan.
I'll be running AO50's again.
So you going to have kiddy fliddling 25 power for 2011 SL Russ or are you going to be sticking with 20 power?
Russ has gone to a dirty cheater 25 I hear..........
It's true.
Check out the build photos on facebook. Engine being dropped in next week all going well. Prob going twin scroll T4 housing on my 3076, mounted on Noel's (FineLine) 6boost that will be in the post when postal services resume in QLD. Should be about 280-300 reliable killa wasps. I'll be starting up a build thread when I get a chance. Maybe not as epic as yours bris.
I want a 1min 42 in august :P
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
