1 10 Mitsuhiro Kinoshita Garage Revolution ( JAP ) Mazda RX7 PRO 3 3 1:30.6160*
2 1 Tarzan Yamada Cyber Evo ( JAP ) Mitsubishi Lancer Ev PRO 3 1 1:30.8220 0:00.2060
3 4 Kouta Sasaki Panspeed ( JAP ) Mazda RX7 PRO 5 5 1:32.0450 0:01.4290
4 5 Mark Berry Advan/Hi Octane Racing Nissan R34 GTR PRO 5 1 1:32.3630 0:01.7470
5 6 Garth Walden Tilton Interiors Mitsubishi Lancer Ev PRO 3 1 1:32.4470 0:01.8310
6 14 Steve Glenney GT Auto Garage/HKS Aust Nissan R35 GTR PRO 9 9 1:33.0120 0:02.3960
7 16 Earl Bamber MCA Suspension Nissan Silvia S13 PRO 2 2 1:33.9720 0:03.3560
8 7 Anda Suzuki Scorch Racing ( JAP ) Nissan Silvia S15 PRO 4 1 1:34.3080 0:03.6920
9 12 Tarzan Yamada Mercury Motorsport Nissan R35 GTR PRO 3 3 1:34.3370 0:03.7210
10 11 Jono Lester Team RevolutionNZ ( NZ ) Mitsubishi Lancer Ev PRO 4 1 1:34.8240 0:04.2080
Just looked at it again and it did get erased?? Moved back down? Why!
go the RWDs!
2 2 David Empringham Sierra Sierra Mitsubishi Lancer Ev PRO 1 1 1:30.7490 0:00.1330
3 1 Tarzan Yamada Cyber Evo ( JAP ) Mitsubishi Lancer Ev PRO 3 1 1:30.8220 0:00.2060
rwd leading the Open Class too. I think that's a 2J powered 180SX?
12 55 Simon Morpowa Racing Nissan 180SX OPN 5 4 1:35.7790 0:05.1630
Edited by hrd-hr30
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
